rear hatch alignment adjustment
Old Jun 11, 2006 | 04:12 PM
dbriana's Avatar
dbriana
Default rear hatch alignment adjustment
Is there any way to adjust the back glass, mine is clearly misaligned, right side barely clears, make horrible squeak to trim when driving. Do you have to have the glass unglued or can you adjust the glass alignment through the hinge part? TIA
Old Jun 11, 2006 | 10:40 PM
Black94LT1's Avatar
Black94LT1
Cruise-In 10-11-12 Veteran
St. Jude Donor '09-'10-'11-'12-'14
Is the spacing around the mount even on all sidew with the rest of the halo? If so, I am guessing the the glass would have to be unmounted. I have never seen anyone have to adjust it, but it would seem like there would be some adjustments in the hinge area, but I would check the current alignment first.
