"surging" when the rpm drops.
Old Aug 28, 2001 | 03:30 PM
Kale's Avatar
Kale
Default "surging" when the rpm drops.
If I rev it up in neutral, as it goes down it sounds like this:
2.5k Vrrrrr...
2k Vrrrr..
1.75k BRURRR
1.7k Rrr..Vrrr..
1.5k vrrrrr
1.25k vrrrr
1k BRURURUR
740 Rrrvrrr
600 vrrrrrrrrrrrrrrrrrrrrrrrrr....
It stopped after i put new plugs in, but started again the same day. Performance seems alright, and gas mileage seems to be on target.
Any ideas? Dirty injector?
Old Aug 28, 2001 | 03:54 PM
CanoeU's Avatar
CanoeU
Default Re: "surging" when the rpm drops. (Smash)
My L98 Had this problem, replacing the plug wires did the trick.
Old Aug 28, 2001 | 04:13 PM
Kale's Avatar
Kale
Default Re: "surging" when the rpm drops. (MattJungels)
Wow, wires are "new" too. hmn..
maybe they're just too close together, or something?
I have uh.. makeshift spacers.. o nthem.
Old Aug 28, 2001 | 06:48 PM
1991Z07's Avatar
1991Z07
Most likely it is the IAC (Idle Air Control) servo that is either dirty or about ready to go out.
This is fairly common on the L98's. The IAC is the solenoid on the throttle body front, bottom right (from seat) and either the spring is going out, the motor is going out, or the seat that the plunger seals against has a carbon build-up on it.
Old Aug 28, 2001 | 08:38 PM
J Z06's Avatar
J Z06
Default Re: "surging" when the rpm drops. (Joe90)
Smash.....
My car would start/stall start/stall. Then, it'd learn the procedure back and run fine. two days later, start/stall start/stall. replaced the IAC... ZERO troubles.
Old Aug 28, 2001 | 09:32 PM
Kale's Avatar
Kale
Default Re: "surging" when the rpm drops. (JD 90 383)
Hmn.. you know, twice its started, and stalled if i let off the gas. in other words, i had to keep the idle up.. HMN.. The part cant be too expensive, or hard to replace. Right?
Are there any adjustments, or is it just in and out?
Old Aug 29, 2001 | 03:42 PM
1991Z07's Avatar
1991Z07
Just replace it. The IAC cycles on start-up from open to closed and back open again. This tells the computer where it is. No adjustments necessary.
While you have the throttle body off, it's a good time to clean out the plenum, install the coolant bypass and I'd even replace the TPS (Throttle Position Sensor) while I was in there. Check your shaft bushings to see if they are worn out. If it wiggles a little, replace the throttle body. Air leaking past the shaft can wreak havok with the computer trying to optimize the idle circuit.
All together, figure an afternoon (2-3 hours tops) to finish it.
Old Aug 29, 2001 | 10:38 PM
BADMUDE's Avatar
BADMUDE
Famous last words..:D
You forgot the "C" word...Corvette...
Old Aug 29, 2001 | 11:27 PM
Kale's Avatar
Kale
IAC replaced. Surging is gone, car idles like a Benz.. :D
Old Aug 30, 2001 | 12:54 AM
J Z06's Avatar
J Z06
Glad to hear it.
To "surging" when the rpm drops.
