Rear window defogger relay?
Old Aug 28, 2001 | 04:56 PM
russell1755's Avatar
russell1755
Default Rear window defogger relay?
I cannot get current to my rear window defogger. The fuse and circurt breakers check ok, but I read something about a relay. Does anyone know where this would be?
91 coupe red (all stock) :confused:
Old Aug 28, 2001 | 06:28 PM
weekendwrench's Avatar
weekendwrench
Default Re: Rear window defogger relay? (russell1755)
On my 87 the manual says it is behind the heater and AC control assembly. Sounds like it may be attached to the assembly.
Old Aug 28, 2001 | 07:20 PM
David-F's Avatar
David-F
Default Re: Rear window defogger relay? (weekendwrench)
Were are you checking for power? check down at the bottom of the rear hatch lift piston jump a test light from one side to the other. The lift pistons can loose continuity through them some times especialy if the ends loosen up. Also there is a 25 amp A/C fuse that powers the relay that needs to be checked. In most cases I have fount a poor connection at either end of the lift piston or a end loosening up or a broken wire on the rear glass. The relay is above the right side hush panel under the dash.
David Fulcher
To Rear window defogger relay?
