MAF Help
I am getting a good 5 volt signal on wire "c" with the sensor disconnected ("c" = signal wire). Hook it up and check the signal and I get 2.18 volts. Man am I confused with this one. Can anyone help??
Can someone please scan their car with the key on engine off and tell me what they read for MAF grams. Any ideas will be appreciated.
During crank, before the engine starts, I will start seeing actual flow values well below the 23 gram/sec initial offset.
I have also recalibrated my MAF tables to better fit my cars behavior.
Note:the first value in the stock MAF table #1 is artificially high (it kicks up to 8.4 gm/sec at 0 volts), which causes an overestimate of the airflow. This could be part of your rich condition.
Crank fueling is not dependent upon MAF flow. If you're too rich after it fires then the MAF calibration and start-up fuel enrichment and or fuel pressure could be responsible.
I just got the non-adjustable one from ZIP products and the calibration is way off.
+ 17 % Flow error as compared with my old OEM Bosch MAF.
I'm now rescaling my MAF tables by a factor of 0.85 to get the flow back where it should be. The raw signal is pretty noisy for flow over 230 gm/sec, it will jump up and down about 20 gm/sec, but the filtered signal looks ok.
With the bosch MAF the filtered and unfiltered values were almost identical, so I disabled the filter. This had to be reversed for the new MAF.
Strangely on the first drive with the artificially increased flow, I was seeing blms in the lean range (130-136). This is the opposite of what I would have expected, with an inflated MAF reading. Load is also skewed high.
The car runs ok, but not quite right. The idle and throttle response is a bit off. Hopefully this will improve with the new MAF table cals.
