Alternator going bad?
Old Jun 12, 2006 | 10:42 PM
skybolt31's Avatar
skybolt31
Default Alternator going bad?
when I start the car, there will be a buzzing that seems to come from the rear speakers, and it is related to engine speed. It is not affected by the volume control and when I shut the radio off, it stops. It will do this for 3-4 minutes after the car starts and then is fine. This is an 86 with the stock Bose stereo. I am wondering if is an alternator going bad and giving off some RF noise when it is charging the most or just another Bose issue.
Old Jun 13, 2006 | 12:22 AM
bogus's Avatar
bogus
no, the amps are dying.
there are caps on the amp boards that rot out and ooze goo. replace the caps and life is good.
Old Jun 13, 2006 | 12:31 AM
RRT vette's Avatar
RRT vette
Yes, I agree with Bogus. This is not an alternator issue.
Old Jun 13, 2006 | 12:34 AM
jfb's Avatar
jfb
You have symptoms of a poor battery connection too! First, disconnect the battery cables (neg first) and clean the cable lugs, battery posts, and bolts and replace the cables (neg last). You want your battery cable connections to be like your lover, bright and tight!
Old Jun 13, 2006 | 12:59 AM
RRT vette's Avatar
RRT vette
or clean and tight!
To Alternator going bad?
