88 alternators
Old Aug 28, 2001 | 08:13 PM
88JDO's Avatar
88JDO
Default 88 alternators
I was looking through my shop manual and came across some information about the charging system. It stated that there are two alternators available, the CS-130 and the CS-144, the difference being the measurement of the laminations of the stator. One is 130mm and the other is 144mm. I looked through the sales brochure for 88 and it doesn't mention an option for the charging system. Is the CS-144 available? The shop manual only covered rebuilding the CS-130. My curiosity has be aroused. Anyone know anything aboput this?
Old Aug 28, 2001 | 09:32 PM
Z-ZANY's Avatar
Z-ZANY
Default Re: 88 alternators (88JDO)
I pulled my alternator last year, dropped it off at a rebuild shop they told me it is the exessive heat under the hood that beats up the c-4 alternators so they upgraded it to resist the heat for around $75.00 and I picked up a new serpentine belt while I had it off at NAPA total cost was under $110.00 faily simple job.I'm pretty sure any alternator can be rebuilt. I also have a 88 have not had any problems with battery since. Hope this Helps also you will still have the original in the car. Jim :chevy
