Oil pressure on C4
Old Jun 13, 2006 | 06:39 PM
tckylem's Avatar
tckylem
Default Oil pressure on C4
My C4 has an oil pressure reading of 20 when at idel. I tend to think this is low. If so how hard is it to fix? Getting to the oil pump I mean.
Thanks,
Kyle
Old Jun 13, 2006 | 06:53 PM
bogus's Avatar
bogus
That is perfectly normal. Don't worry about that one bit.
Old Jun 13, 2006 | 07:30 PM
AKS Racing's Avatar
AKS Racing
20 psi at idle and 10 psi per 1000 RPM is a good rule of thumb.
Aaron
Old Jun 13, 2006 | 07:47 PM
CFI-EFI's Avatar
CFI-EFI
Thanks,
Kyle
The oil pump does not create pressure. The pump creates flow and it is the resistance to that flow that causes pressure. You can increase the pressure by increasing the resistance to flow. Such as by tightening up in the main and rod bearing clearances.
RACE ON!!!
Old Jun 13, 2006 | 08:26 PM
vader86's Avatar
vader86
If thats a hot idle, say 190-200+, then its fine.
Old Jun 13, 2006 | 08:33 PM
fsr402's Avatar
fsr402
Cruise-In VI Veteran
Cruise-In VII Veteran
St. Jude Donor '06
I had an old TA that would run at 5psi. Then jump to 80 as soon as you gave it some gas.
20 psi is normal and just fine. As long as it goes up with RPM.
Old Jun 13, 2006 | 09:04 PM
madmatt9471's Avatar
madmatt9471
From: Palmdale, Ca----- 2009 Cyber Gray 4LT A6 F55 452 RWHP 422 RWTQ- RIP 1998 C5 734 RWHP & 585 RWTQ-----
Your okay! your pressure is not to low! if you want it to go up a little then run some synthetic oil with a little more weight!(if it bothers you, I went from 5w30 to 10w40 and am pleased with the results, especially here in the heat of the Ca. desert)
Thanks, Matt
Old Jun 13, 2006 | 09:09 PM
bogus's Avatar
bogus
RACE ON!!!
To Oil pressure on C4
