Will LS1 26.8 lb Injectors Work?
Old Jun 14, 2006 | 08:03 PM
danziger's Avatar
danziger
Default Will LS1 26.8 lb Injectors Work?
I have an extra set of injectors from when I upgraded my LS1. Do you think they'll feed a mild 383 L98? thanks!
Old Jun 14, 2006 | 11:28 PM
USAsOnlyWay's Avatar
USAsOnlyWay
Fed mine fine, I also used a dremel to make it so I could use the stock retainer clips. (426/520 at the flywheel )
Old Jun 15, 2006 | 12:00 AM
Corvette Kid's Avatar
Corvette Kid
Large Impressive Member
From: Good health is merely the slowest possible rate at which one can die
St. Jude Donor '04-'05-'06-'07
They should. I have LS6 injectors in my LT1.
Old Jun 15, 2006 | 12:09 AM
Corvette Kid
BTW, is this the rating on these injectors in the LS1? Be advised that unless you bump your fuel pressure to LS1 specs that they will effectively be a smaller injector in your application.
Old Jun 15, 2006 | 06:28 PM
danziger's Avatar
danziger
Good point. I think the LSx engines run at 50psi line pressure. What can I safely adjust the fuel pressure to on a L98? Thanks!
Old Jun 16, 2006 | 08:21 AM
rodj's Avatar
rodj
I believe they are rated a 28lb@58psi (LS1 pressure )so probablely more like 24lb at L98 pressure
From Five O site
Bosch LS1 -
Use this set for all 1985-1991 L98, 350cid engines.
This LS1 injector incorporates faster pulse rates and a finer more efficient spray for added power response and economy.
Old Jun 17, 2006 | 02:30 PM
danziger's Avatar
danziger
Hmmm. 24lbs should still be adequate, if not optimal., correct? Thanks!
To Will LS1 26.8 lb Injectors Work?
