I was reading some interesting threads concerning changing out the Clutch fluid resevior. I looked under the hood of my C4 and didn't see the resevoir. I figured that it is located somewhere on the drivers side, near the brake resevoir. Can someone point me to the location?
Also, what fluid does everyone recommend. I was just going to step by the dealership and pick-up GM's, since I figured that is probably what is in the car.
If the car has GM fluid in it, is it fine to mix, or should I stay with the same fluid. I had some work done to the clutch last year from the dealership, so I am guessing they filled it with GM fluid
