Choppy dyno
Old Jun 15, 2006 | 07:35 PM
fredk's Avatar
fredk
Default Choppy dyno
I just got back from the dyno with my 93. From 0 to 5000 it is nice and smooth, from 5000 to 6300 it is very choppy, does anyone have any ideas. Everything has been replaced opti, wires and plugs. By the way she made 347rwhp and 334 ft lbs of torque.
Fred
Old Jun 15, 2006 | 08:40 PM
95wht6spd's Avatar
95wht6spd
It will help a lot if you post the graph. Since you have covered the other things, I would say it could be your coil, fuel pump, or fuel filter, maybe even cloged injectors?
Old Jun 15, 2006 | 09:31 PM
fredk's Avatar
fredk
Everything you have listed has been covered. I will have to figure out how to scan and post.
Fred
Old Jun 16, 2006 | 12:06 AM
Lichen's Avatar
Lichen
Mine was really choppy when the A4 was going out. Now it is nice and smooth.
Old Jun 16, 2006 | 05:14 AM
TIMSPEED's Avatar
TIMSPEED
Originally Posted by fredk
from 5000 to 6300 it is very choppy.
Try an MSD 6a box. I dunno about you, but imho 5000-6000 is pretty high rpm...usually HEI's fall off around 5000rpm, so...but with the Optispark, it's a little better quality..but still, you never know.
Old Jun 16, 2006 | 06:34 AM
ben73's Avatar
ben73
valve springs???
Old Jun 16, 2006 | 09:16 AM
87 rag's Avatar
87 rag
347/334 is pretty good fred.
Just for fun my dyno last year showed 220 rwhp/323 lbs torque.
What were you expecting or hoping for?
Sorry, can't help with why it's choppy.
Jeff
Old Jun 16, 2006 | 06:22 PM
88BlackZ-51's Avatar
88BlackZ-51
Those # sound like around 425chp. I gain of approx. 125chp from stock.
If your ignition is stock, I think that might be the problem, but then again, I cant see much more then 350rwhp from an automatic with your mods, I think your doing good!
Now get some tires, and start running low 12's! You have the MPH to run solid 12.30's. I smell 1.70-1.75 60 foot's.
Old Jun 19, 2006 | 08:57 AM
88BlackZ-51
Jeff
you torque monster you.....
Old Jun 19, 2006 | 09:12 AM
87 rag's Avatar
87 rag
I need the extra torque for when I'm pulling the trailer and snowmobiles.
Old Jun 19, 2006 | 11:53 AM
DieL's Avatar
DieL
Fred
My guess is also valvesprings. Do you have roller rockers? If so it could be a lifter or fatigued springs. Also could possibly be ring flutter. I think in 96 the lt4 had a different ring just because the LTs had ring flutter over 5k rpm.
Hook up a fuel pressure guage to the schraeder valve and tape it to your windshield. go for a drive and hammer it in 2nd gear + and see if the pressure drops or gets shaky at those rpms. if so its probably the pump
To Choppy dyno
