C-4 to C-5 Brake Conversion
Old Jun 18, 2006 | 01:20 AM
chfakers13's Avatar
chfakers13
Default C-4 to C-5 Brake Conversion
Does anyone know if it is possible to replace C-4 calipers with C-5's. If so what all is involved. Thanks
Old Jun 18, 2006 | 01:54 AM
vader86's Avatar
vader86
You have to convert everything, not just calipers.
http://www.superchevyperformance.com.../c5brakes.html
All those parts, plus you will need an adapter made for your year. Brake lines from any year c4 work with the C5 calipers.
Old Jun 18, 2006 | 05:10 AM
USAsOnlyWay's Avatar
USAsOnlyWay
http://forums.corvetteforum.com/show...light=c5+brake
Old Jun 18, 2006 | 06:44 AM
cakes751's Avatar
cakes751
I wouldn't waste my time with the switch from c4 calipers to c5's...I was just considering doing the same work and opted for a wilwood front and rear kit...have the brakes on the car for about a week...they are sick!!!...my car brakes better then a new Z06.....seriously...I got the parts from tbyrne motorsports...they were great....the front kit came with rotors, pads, braided hoses, and 6 piston superlite calipers...for the rears, I kept stock calipers and put on wilwood rotors, pads, and braided hoses...I couldn't be happier...all told, the parts ran me a lil' over 2 grand...but, it's been well worth the price of admission!!!...hope this helps...Brian
Old Jun 18, 2006 | 09:33 AM
PLRX's Avatar
PLRX
Co-winner 2020 C4 of the Year - Modified
2017 C4 of Year
2016 C7 of Year Finalist
St. Jude Donor '09 thru '20
I just installed the C5 Z06 brakes in my 95. There is a big improvement. Total co$t: $850
"Click"
Old Jun 18, 2006 | 06:13 PM
DON M's Avatar
DON M
I have C-5s on the front and the stock rears work well enough to pull down the 315x35x17 tires on the back.
Great bang for the buck Mod.
Old Jun 18, 2006 | 06:22 PM
Red_Vette_93's Avatar
Red_Vette_93
"Click"
did mine for $540, just have to put in biased spring
Old Jun 18, 2006 | 06:54 PM
ToniH's Avatar
ToniH
Well, I did and I am very happy with them. I can lock my brakes at will (engage ABS I mean) and haven't been able to overheat them during track days. What more do you get with 2-3x the price of C5 kit? Did you get 2x the performance? 3x? I doubt it.
I also have experience with big Brembo brakes - in a Porsche. Still I am happy with my C5 brakes which really are an improvement over stock C4 stuff.
They worked nicely straight on but later I added the DRM balance spring and liked the results even more.
Old Jun 19, 2006 | 06:51 AM
cakes751's Avatar
cakes751
it makes sense, if your looking to save money to do the c4 to c5 zo6 conversion...I've heard good things about this mod...I was just very skeptical of having to add adapter brackets and the fact that you may have to change your rims...which will run at least another $800 to do it right...that adds to almost the 2 grand the wilwood kits cost me and I couldn't be happier with the performance...it's the same setup that track cars are using on the gt pro circuit....but, if you don't intend to take the car on the track, the c5 kit would be more then adequate...I guess it all depends on how your gonna use the car...I'll tell you one thing though...the car looks soo much hotter with hard core aftermarket kits (like wilwood, mov'it, stoptech) then with standard gm parts...
Old Jun 19, 2006 | 12:47 PM
CrvtBB's Avatar
CrvtBB
Veteran: Coast Guard
I've seen C5's/Z06's run on the track all day without any problems and great performance. With the right set of pads you will likely get 90+% of the performance of a Wilwood or Brembo setup for about a third of the cost. Plus, replacement rotors and pads for C5's are VERY reasonable.
It was based on my observations at the track that I decided to do the C5 upgrade. Highly recommended -- and make sure you get the DRM spring.
Old Jun 19, 2006 | 01:14 PM
ccford's Avatar
ccford
I would like to make this conversion on my 93 and keep my original wheels. I get the feel that this does not work with some brackets. Who makes the brackets that allow the calipers to fit in the stock wheels?
Thanks in advance!!
Old Jun 19, 2006 | 05:12 PM
89Corvette6spdFX3's Avatar
89Corvette6spdFX3
Where did you get your parts?
Old Jun 19, 2006 | 07:52 PM
PLRX's Avatar
PLRX
2017 C4 of Year
If you shop around (EBay, Junk Yards, Web Browsing, used parts etc) you may/will get it cheaper than buying an already C5 kit. I bought all parts from different vendors. Rotorpros, EBay and Hawk
To C-4 to C-5 Brake Conversion
