MSD Coil Blaster a good OEM replacement?
Old Jun 20, 2006 | 02:55 PM
boonie's Avatar
boonie
Default MSD Coil Blaster a good OEM replacement?
i've replaced everything on my 93 LT1 ignition system Dyna-spark, new spark plugs, spark plug wires etc... and now iam on the verge of replacing my OEM ignition coil which is 13 years old with 83,000 on it, question how good of a OEM replacement is MSD"s coil blaster? or should i just stick with the OEM ignition coil?
thanks boonie
Old Jun 20, 2006 | 03:13 PM
DougSilver's Avatar
DougSilver
My car (95) was missing and one of the things I did was to replace the stock with an MSD Blaster (#8226). This did not totally solve the problem but the car definitely ran better with just the coil swap.
Old Jun 20, 2006 | 05:50 PM
rocco16's Avatar
rocco16
From: SCMR Rat Pack'r Charter Member..Great Bend KS
A good stock coil will give you the same performance as a good aftermarket unit.
Larry
code5coupe
Old Jun 21, 2006 | 09:10 AM
onedef92's Avatar
onedef92
Cruise-In IV Veteran
Cruise-In VI Veteran
Cruise-In VII Veteran
Cruise-In VIII Veteran
Larry
code5coupe
The O.E.M. coil is just fine.
Old Jun 21, 2006 | 10:44 AM
SJW's Avatar
SJW
thanks boonie
Unless you're going to be revving this engine way north of the factory redline (which will require reprogramming the rev limiter), stay with the OEM coil. It is more than adequate for the task.
Be well,
SJW
Old Jun 21, 2006 | 11:20 AM
Redeasysport's Avatar
Redeasysport
St. Jude Donor '05-'06
I have one on my car.It does not add much if anything to performance but looks cool as it is red.Every ignition part I have replaced had resulted in some kind of better performance possibly due to aged parts or better quality.I have done the reasearch on coil operation and it depends more on the plug gap as far as spark goes and as long as it provides enough volatage to do it there is no added benefit from using a higher volatge producing coil as the arc over voltage remains the same.
Old Jun 21, 2006 | 12:02 PM
rocco16's Avatar
rocco16
Precisely.
Larry
code5coupe
Old Jun 21, 2006 | 12:26 PM
~db~'s Avatar
~db~
I have the MSD and it works fine. Is it necessary or beneficial?? As many have stated, probably not. But when you compare the price to a new OEM unit, you may be surprised.
Old Jun 21, 2006 | 12:50 PM
MR.KIDD's Avatar
MR.KIDD
I had one that lasted a whole month and I have 2 buddys that had them last 4 and 6 months, maybe we where just lucky.
Old Jun 21, 2006 | 02:24 PM
Impala Balko's Avatar
Impala Balko
The Blaster 2 coil is complete garbage hooked 3 of them up to my 94 Impala SS and they kept shorting out after awhile and burning out leaving me stranded. Luckily they were covered under warrantee. but after the last one I just said the hell with it. I dont know how much performance it gives you but with the Blaster 2 coil and MSD 6al box it did give me better throttle response but it wasnt worth the headaches of breaking down and compromising reliability.
Old Jun 21, 2006 | 08:08 PM
rickneworleansla's Avatar
rickneworleansla
I just ordered one new for $32 on ebay. Not a bad deal, couldnt pass it up. My stock one was fine and will be kept as a backup. At 80k miles, I wanted to upgrade some things including ignition parts. I have never had any problems with past MSD parts. Most of their stuff is well made. I will let you know if it craps out.
Old Jun 21, 2006 | 10:58 PM
Impala Balko
Just do what I did and just unhook the wires from the old coil but leave it still installed on the motor that way if you do break down you can plug in the old coil and be on your way
Old Jun 22, 2006 | 08:17 AM
xflagz51's Avatar
xflagz51
I've had trouble with the MSD Blaster internal coil on my '90. I've gone through this twice using brand new MSD coils from Summit Racing and had the same result. The factory tach wigged out at about 3800 RPM and it must have screwed up the signal going back to the computer to advance the timing. Best quarter mile with the MSD was a 14.9, put the factory coil back in, complete with 112K miles of use and scored a 14.0 at 100. Figure that one out!
Adam.
Old Jun 22, 2006 | 11:37 PM
Redeasysport
Mabey some of MSD's rep is undeserved based on what you guys say.Can't wait for the first failed MSD opti thread then.It will make me feel better about my overpriced Dynaspark.
Old Jun 23, 2006 | 12:28 AM
TorchRedlt4man's Avatar
TorchRedlt4man
From: Chicago Executive Airport, formerly known as Palwaukee
No-IL Events Coordinator
St. Jude Donor '12-'13-'14-'15-'16-'17
I am running the Accel ignition coil for my LT4. I know they make one for the LT1.
I am also running the Accel 300+ ignition box.
I believe both parts were instrumental in eliminating a high speed miss. The miss was documented on Dyno runs.
No miss now!
I am a very satisfied Accel customer!
Old Jun 23, 2006 | 02:48 AM
DYNASPARK's Avatar
DYNASPARK
Old Jun 23, 2006 | 02:54 AM
REDC4CORVETTE's Avatar
REDC4CORVETTE
I tried the Jegs coil and burnt that one to the ground in a week.
I got the MSD coil and burnt down the 6al MSD box.Replaced the box a year ago and everything has been fine since.
To MSD Coil Blaster a good OEM replacement?
Old Jun 23, 2006 | 11:12 AM
rickneworleansla
Has anyone ever had success with an msd coil for the LT1??
Old Jun 23, 2006 | 01:03 PM
Redeasysport
Originally Posted by DYNASPARK
Sorry Dynaspark it is not what I really mean.To elaborate the guys who have been promoting the MSD over your product have infered that thier quality and because it is cheaper means it is better than yours.I do not agree and having one of yours in your hands you can see the quality built into it.It has a proven track record of no failures due to lack of quality.Only failures I have read were due to install issues.I am and was willing to pay a little more for that kind of piece of mind.I can do without the fancy colored cap and new whiz bang opti sensor(The old one is the most durable part of the ignition system and needed no improvement) that probably came from China.Sure the Mitsu sensor was from Japanbut thier quality record is well known.
Old Jun 23, 2006 | 01:04 PM
Redeasysport
Mine has been working fine for over a year
