How to test AC Compressor
Old Jun 21, 2006 | 01:41 PM
1986coupe's Avatar
1986coupe
Default How to test AC Compressor
I am not sure if my ac compressor is working on my 1986 Coupe. How should I test to see if it is still good?
Old Jun 21, 2006 | 01:56 PM
Jerris's Avatar
Jerris
1. Start engine.
2. Turn on AC while observing the compressor to see if the clutch energises and turns the compressor.
3. If compressor turns, Check the AC lines going from the compressor with your hand to see if it gets cold.
4. If line gets cold, check vents inside car to see if they are blowing cold air.
5. If all above checks out go for a drive and enjoy that AC. If not post where in the sequence there is a problem and the members here will walk you through a fix.
ONE FINAL NOTE.( or should that be first note)
Before doing the above, disconnect your negative battery cable for 3 minutes and reconnect it. This will reset the computer to send the signal to the compressor if it had shut down because of a code.
Old Jun 21, 2006 | 02:27 PM
SunCr's Avatar
SunCr
No codes before '90 so need to disconnect the battery.
Assuming the compressor engages, you want to feel the bigger line from the top of the Evaporator and the one at the bottom - JUST where it enters the Evaporator case. Touch that smaller, bottom line, anywhere else and you might burn your hand! Both lines should be cooler than ambient with the top maybe a bit cooler. If so, and the compressor engages, charge is at least close - something else is keeping cool air from getting to the vents.
Old Jul 28, 2025 | 08:49 PM
Sfd6533's Avatar
Sfd6533
I just pulled all the a/c stuff out of a box and installed it with all new green o-rings, accumulator, oil and 12 oz of 134A. The compressor clutch never engaged. I checked the fuse and made sure it is plugged in. How can I test?
Old Jul 28, 2025 | 10:27 PM
CorvetteRules's Avatar
CorvetteRules
The last time the poster of thread was active was Nov 26, 2018 03:52 AM. It would be best for you to start a new thread detailing the issue you're having.
To How to test AC Compressor
