OK, labor day weekend is a 4-day for me, I already have Friday and Saturday set aside to change a leaky water pumpm, but I also picked up some new valve cover gaskets, because I want to adjust my valves due to a slight ticking in one on the drivers side. The helms manual is very specific about non-running adjustment based on TDC and timing, but I have heard other methods. Could someone please explain some of the other methods for an '86 L98 and give me any results/pros/cons?
Just to pass a note, be sure the ticking you hear isnt a injector firing, injectors can tick pretty loud sometimes and people have mistaken the noise for a lifter.
I would recommend adjusting them running. If you do it this way you will need to have the engine idling. I would only remove one valve cover at a time because oil will be spraying out the pushrods. You can buy oil deflectors to clip on the rocker arms to help control the oil.
You will first loosen an adjusting nut until the lifter just starts ticking, then tighten 1/2 turn and move on to the next rocker. Many people will have opinions on how far to turn the adjusting nut. I use 1/2 a turn some use 1 full turn.
Tryinng to adjust the valves cold with oil in the lifters is difficult. It is difficult because finding zero lash (the point when the lifters start to tick) is hard to determine by feel when the lifters are full of oil.
Removing the valve covers can be a bit of a pain. The a/c compressor is in the way on the passenger side and the smog pump is partially in the way on the drivers side.
Buy good gaskets is the best advice I can give you.
Stethescope or a long screwdriver against your ear and put it where the noise is.
Another is, unplug the injector that may be suspect when its running and see if it(ticking) goes away, but there will be a slight stumble to the car running when doing so since it wont get gas for a moment.
Btw, not sure of the gaskets youre getting...if its the rubber kind that you stretch on, t has a tendency to pop off as you go to place the cover back down..its tricky holding the gaskets in place with your fingers while placing the cover on.
SOme people use weatherstrip glue adhesive, just a ittle bit and stretch the gaskets on and let it dry a bit to hold it in place.
Either methods are good.
My fel pro rubber gaskets were like this...had to stretch them and hold them carefully while placing the cover on...they NEVER leaked on me...made me very happy.
:D
:cheers:
86 Coupe,
To determine where the ticking is coming from use a screwdriver or prybar as a stethoscope. Place the screwdriver against the injectors and your ear, one at a time, you will often find one that is loudest, this may be what you are hearing. Do the same thing right on the valve cover, if everything is OK, it will sound like a washing machine in there, no ticking or anything. Best of luck.
If it ends up coming from an injector, does that mean it's terminal? If so, I assume it's highly recommended to replace them all, or can I just change the one that is bad?
Some ticking is normal from the injectors. If one is much louder than all the others that might be a problem. I would not recommend replacing only one because of the amount of work involved with removing the runners and plenum. You can have the old injectors cleaned and flow tested. Do a search on the forum for recommended shops to send them to if you go that route. As the other post metioned you can disconnect the wire from each injector to see if the ticking stops. You can also measure the resisitance of each injector. They should all be close to the same. I think in the neighborhood of 14 to 16 ohms. But don't quote me on that.
