Shining up the tpi intake
Old Jun 25, 2006 | 03:27 PM
Black_Vette's Avatar
Black_Vette
Originally Posted by cplonner
That looks really good, I have the edelbrock runners on there now. So you sanded then polished? Im pretty much looking to make it look nice but not "chrome like". I might get carried away though. What sand # and polish did you use?
Ya I started sanding out the casting marks using 800 grit paper then finished with 2000 grit, then used different polishes to bring out the shine a lot of work but well worth it. Red rouge polish, then Tripolli, then mothers aluminum polish.
Old Jun 25, 2006 | 04:27 PM
JustForFun's Avatar
JustForFun
My plan when i put the car up this coming winter is to take the TPI ysytem off and have it chromed. matter of fact i plan on adding a good bit of chome this coming winter
Old Jun 25, 2006 | 04:38 PM
LS6 Motor's Avatar
LS6 Motor
I removed my intake, and had it powdercoated, partly because it also had the traditional oil leak. I also did the plenum, runners, valve covers, and associated brackets. The process used was to media blast the parts, powdercoat, bake @ 375 degrees for twenty minutes, then clear coat, and bake again for twenty minutes. The nice thing with powdercoating is it is a world of colors, and the more parts you do, the cheaper it becomes per part. My avatar is a picture of my recently completed motor.
Old Jun 25, 2006 | 07:24 PM
cplonner's Avatar
cplonner
Looks good! Im gonna have this done by the end of the week and Ill try to post some before and after pics. Some new valve covers and a shine will make it look nice. It will be a diamond in a goats *** the way my paint job looks right now too.
Old Jun 26, 2006 | 11:17 PM
Insane1's Avatar
Insane1
I did mine slightly different. Didn't go with the 'complete' polished look.
Old Jun 26, 2006 | 11:50 PM
corvette_crimson's Avatar
corvette_crimson
Looks nice,
It definately gives your engine compartment a wake up when you do some thing to the bland look of the original intake.
