Newby here...
Old Jun 27, 2006 | 10:40 AM
Twinamp's Avatar
Twinamp
Cruising
The monsoons continue. I haven't been able to work on the 'vette. Ten frigin inches of rain in 3 days. !
Twinamp
Old Jun 29, 2006 | 09:34 AM
Twinamp's Avatar
Twinamp
Cruising
Well the monsoons stopped long enough for me to get out to look around. Remember this is a new car to me as well as a new type of car. So I'm learning. First thing I noticed was an empty separated in line fuse that attached to the terminal of a small cigar box shaped item that sits behind the battery. (Anybody recognize this?) I closed up the in-line holder and taped it so that it could not come apart and short out. Whether it was before or not will probably never be answered. It was not shorted when I opened the hood and I could not see where it could contact ground but that doesn't entirely rule it out as a culprit. I also failed to locate where the ohter en of the wire went yet. But we ain't done looking yet!
I started her last night and let her idle and she did fine. I let her temp get to about 220. Everything ok. So I took a short hop to the library and while there remembered that each time problems occurred was the second or later start. Started and drove home no problems. Temp never exceeded 225. At home I allowed her to idle and at about 228 she surged and returned to normal. At 230 the fan cut on. ok! Temp droped back to 2+mid teens. Fan went off. ok! Temp climbed up again and around 228 surge occured again. Still it didn't cut off. Fan repeated its performance again. Drove it a bit but no problems. It was a lo t cooler last night than it was both days that it died. Looking over various posts on this site I am concerned that the OPTI that was recently replaced by the former owner just MAY not be worth a crap when the temperature climbs. I don't trust it so I'll probably let it sit at idle on the next hot day and see what happens.
Looking it over I found a couple of spliced leads to various sensors, one near the water pump. Being and old tube guitar amp jockey I REALLY was unimpressed with the work that I saw. Gogs of electical tape wound around a splice. I OBVIOUSLY am going to have to take a trip thru this young lady and check her out.
This ain't the way I envisioned my first couple of weeks with my 'vette!
Twinamp
