Look what I found!
Old Jun 24, 2006 | 08:24 PM
ALLT4's Avatar
ALLT4
Default Look what I found!
During my disassembly for a cam change. Anyone care to guess what the gap on that silly thing is? I had to use a slide gauge to measure it! Looks like I found my high RPM stumble. This kind of plug will NOT be going back in.
Old Jun 24, 2006 | 08:27 PM
DG'sVette's Avatar
DG'sVette
Old Jun 24, 2006 | 08:30 PM
ALLT4's Avatar
ALLT4
Originally Posted by DG'sVette
1.22
Well it's more than half that.
Old Jun 24, 2006 | 08:46 PM
aminnich's Avatar
aminnich
.90 gap and a/c platinum plugs?
Old Jun 24, 2006 | 08:48 PM
bogus's Avatar
bogus
I am all over the AC Delco Platinums... those POS pucks fall off all the time.
Nominally, once the puck goes away, the gap grows to .065.
Old Jun 24, 2006 | 09:00 PM
Tom Piper's Avatar
Tom Piper
Two pucks and it is close to .100".
When I did my heads and cam at 55K, I only had two plugs with both platinum pucks still on them.
The larger the spark plug gap, the more voltage it takes to fire the plug, and everything on the secondary side of the ignition system sees that extra high voltage -- including the Opti-Spark cap and rotor.
I've often wondered how many Opti-Spark caps got carbon tracked because the platinum pucks fell of the AC Delco worthless spark plugs.
Tom Piper
Old Jun 24, 2006 | 09:10 PM
zoro's Avatar
zoro
surprised that one plug would fire at all
Old Jun 24, 2006 | 09:16 PM
bogus's Avatar
bogus
Tom Piper
no kidding.
I use NGK plugs for just this reason.
Old Jun 24, 2006 | 10:44 PM
ALLT4's Avatar
ALLT4
It's about 0.105, funny thing is that's the only plug that has somewhat of a puck left on the arm, even though it's hard to tell in the picture.
What's even stranger is the motor seemed to running pretty good with them like that, as far as I could tell anyway. Except the high speed stumble and that didn't happen until about 5000 RPM
I'm really looking forward to getting this back together though it's going to take some time.
With the Hot Cam, new springs, ported heads, and new wires and plugs among other things , it should run a hell of a lot better.
I take it the consensus is NGK's?
Old Jun 25, 2006 | 01:01 AM
Steel Breeze's Avatar
Steel Breeze
I've got a set of delco rapidfire #5's, I haven't installed yet...
Old Jun 25, 2006 | 08:15 AM
larryfs's Avatar
larryfs
what is the mileage on that missing puck ?
Old Jun 25, 2006 | 11:52 AM
ALLT4's Avatar
ALLT4
I bought the car with 85,000 on the clock, there is now 90,000 so I have no idea if they were changed before or if they were stock.
Old Jun 26, 2006 | 01:12 AM
ZMechanism's Avatar
ZMechanism
So the OEM platinum plugs may have lasted 10 years and 90,000 miles and the car still ran good yet the plugs are considered POS? By the way, I have talked to people at many corvette speciality shops including DRM and they all recommend using the OEM AC delco platinum plugs for a basically stock engine.
Old Jun 26, 2006 | 12:19 PM
No Go's Avatar
No Go
I've used the Rapid Fires for several years with no issues. Not the same design as the OEM AC's...they are well known for this issue.
Old Jun 26, 2006 | 12:30 PM
Grease Monkey's Avatar
Grease Monkey
From: Hampton, VA Yea, i'm a redneck... but you love it
Cruise-In 8-9 Veteran
aka/Trunk Monkey/Banned For Life/Corvette For Life
i got the rapid fires and love them
Old Jun 26, 2006 | 03:28 PM
Corvette Kid's Avatar
Corvette Kid
Large Impressive Member
From: Good health is merely the slowest possible rate at which one can die
St. Jude Donor '04-'05-'06-'07
I've used the standard NGKs for a while now in the Vette w/ no problems. This time I bought Autolites just because in my 35 years of wrench turning they've always been the consistently best plug in any kind of engine I've used them in. Re/ gap, my tuner says stock gap is way too wide and would have me set them at .030". I compromise and set them at .035" with good results in my LT1.
Old Jun 26, 2006 | 03:39 PM
ALLT4's Avatar
ALLT4
I can't say whether or not they have been changed before or not, if you look at my last post. Hell it's possible they were changed when it was sold to me at 85,000, who knows.
Old Jun 26, 2006 | 03:42 PM
Fuzzy Dice's Avatar
Fuzzy Dice
Cruise-In IV Veteran
I'm with Corvette Kid NC on this one...I've been using the cheap Autolite's for 3 years now with no problems in my 93...I gap them to .030 and drag race my car 90% of the time...no misses and my car shifts at 5900+ rpm at WOT...it does idle a tiny, tiny bit rough with the small gap but under throttle is smooth as can be...
Old Jun 26, 2006 | 11:00 PM
No Go's Avatar
No Go
I'm unsure of why folks close the gap on a essentially OEM high energy ignition system...one of the benefits of modern engine/electronics???
I mean for nitrous or forced induction, sure, but .030 is a gap that is old school relating to gaps used for points? Even HEI was a larger gap that that back in the early 70's...
Again, I run Rapid Fires with nary a problem and run it to 6900 rpm with a 11.9 measured compression ratio.
To Look what I found!
