Oil Leak
Old Jun 24, 2006 | 08:34 PM
DG'sVette's Avatar
DG'sVette
Default Oil Leak
What is the best way to find an oil leak?
I have a 95 LT1 with 76,0000 on it. Slight oil leak. It hasn't even used a quart of oil between changes (yet). For the most part the oil seems to be dripping from the the oil filter side down to the bell housing.
I'm hoping its not the rear main seal. I gather this would require pulling the engine. What about the oil pressure sensor? Where is this at & could this be the culprit?
I guess it could be 1 of several things, so what I really need to know is what is the best way to find out where an oil leak is originating from.
Old Jun 24, 2006 | 08:40 PM
bogus's Avatar
bogus
The rear main seal would simply leak oil down the bottom and out the inspection shield. It's not that hard to tell.
Your leak is more than likely coming from the intake manifold. It's a common problem. Check the back of the engine (by the firewall) for moisture.
Another good source is the valve covers... check them, too.
How to test for it, you need a dye kit. It has a liquid dye that you add to the engine oil, and a special ultra-violet light, with glasses. Run the car for a few days, checking for the leak with the light and glasses. The dye will turn like bright blue or something. Then you can ID the source.
I think Autozone and places like that are now selling these kits. The glasses and light are sold as a pair, and the dye is in a little bottle.
The dye is also good for coolant leaks, too. There is a special dye used for AC systems.
86PACER's Avatar
86PACER
I like to wipe off the oily areas clean and start fresh. Then I keep a close eye on it with a flashlight. They also sell a dye that you can add to the motor oil. The leak will then clearly show under a black light I beleive.
Old Jun 24, 2006 | 08:42 PM
aminnich's Avatar
aminnich
No secrets on this one. Clean it up best you can and then after running for a while get it up in the air and go underneath with a flashlight. An inspection mirror can help for the tight or hard to see spots. There are also dyes available from auto parts stores to help locate an oil leak. It is very unlikely to be a rear main seal, that would be leaking out from the bellhousing only. For what it is worth I had front crank seal seeping and put 1 pint Lucas Oil stabilizer in with Mobile One on last oil change and no more seepage (so far).
Old Jun 24, 2006 | 11:15 PM
DG'sVette's Avatar
DG'sVette
Thanks guys. I did some clean up on the underside when I changed the oil the other week. Tomorrow I think I will start at the top & work my way down.
Old Jun 24, 2006 | 11:18 PM
DG'sVette's Avatar
DG'sVette
This is probabaly a stupid question but I need to ask.
If it turns out to be the intake, will I have to remove the fuel rails from the intake?
I hate dealing with the fuel lines. I just got down replacing the fuel pressure regulator. It was quick, but I just hate dealing with the fuel.
Old Jun 24, 2006 | 11:27 PM
bogus's Avatar
bogus
yes, you must remove the rails, but, you don't need to remove the lines... just let the rails sit, complete, on the surge tank or something.
Old Jun 25, 2006 | 12:39 AM
MilehighZ51's Avatar
MilehighZ51
Another source for an oil leak is the seal between the oil filter adapter and the engine block. I fixed this recently on my '96 LT4. I believe you have the same adapter on your LT1.
If you see a drop hanging from your bell housing AND from your oil filter, this could be the source.
Good luck!
Old Jun 25, 2006 | 01:16 AM
bogus's Avatar
bogus
Good luck!
yea, that one sucks.
I have had issue with that one over the years. The heat is great there, and between the oil and the heat, the paper gasket turns to stone. It's a real bitch to get off.
I coated my replacement with high tack, hoping it will make it easier to replace down the road. I will report back when that time comes.
Old Jun 25, 2006 | 01:18 AM
lticforce92's Avatar
lticforce92
Default Oil Filter
Make sure your oil filter is not loose. It happens!
Old Jun 25, 2006 | 12:08 PM
DG'sVette's Avatar
DG'sVette
Good luck!
I'll have to check this one. This sounds close to what I'm seeing.
Did you just have to replace the seal or was there more to it?
Old Jun 25, 2006 | 01:14 PM
MilehighZ51
There is a gasket and a large O-ring between the adapter and the block. The dealer offers a kit which contains both pieces.
There are two bolts which hold the adapter to the block. The adapter may require a little persuading to remove, because the inner gasket has hardened pretty well over time and has done a fine job of adhering the two surfaces together. The toughest part of the job is scraping off the old gasket material from the block. As Bogus described, it's a bitch...you need to be creative in your tool selection, because there isn't a lot access to that surface under there. Be sure to wear safety glasses- gasket material will be falling down onto your face!
Good luck!
Old Jun 25, 2006 | 01:26 PM
bogus's Avatar
bogus
I used a pneumatic die grinder with a steel brush on the end... THAT worked... Over time...
There is a chemical gasket removal spray that did help to soften it a bit... everything helps... you just dont' want to gouge the soft aluminum.
Old Jun 25, 2006 | 05:08 PM
DG'sVette's Avatar
DG'sVette
Thanks guys. I'm sure after I get the engine cleaned & run the dye through it I'll be adding to this post.
As for the rest of today its time for .
Old Jun 25, 2006 | 05:09 PM
madmatt9471's Avatar
madmatt9471
From: Palmdale, Ca----- 2009 Cyber Gray 4LT A6 F55 452 RWHP 422 RWTQ- RIP 1998 C5 734 RWHP & 585 RWTQ-----
I take a small mag light and an extention mirror(like the ones plummers use for lookin' around pipes for leaks)! You can direct it to an area and use the flash light to highlight the initial spot. I also look for the highest sign of oil(or wet spot on the motor).This usually works and suits me good, and the mirror should extend at intervals to about two feet(round mirror on the end). Can get one at Home Depot(in AC section or plumming and the tool crib possibly even at the Auto store)
I hope this helps!
Thanks, Matt
Old Jun 25, 2006 | 05:16 PM
MikeC4's Avatar
MikeC4
My bet would be you have a leaking oil pressure sending unit. They are notorious for developing leaks, and dribble right down to your bell housing. You actually have 2 oil press. sending units on your '95. They are located behind your EGR. It is best to remove the EGR to thouroughly check them. When mine was leaking, I would see white smoke(oil burning from hittings exhaust) coming from the front of the hood nearest the drivers side.....Check this before anything else....and like you, I didn't notice any appreciable loss of oil between changes....
Old Jun 25, 2006 | 10:28 PM
DG'sVette's Avatar
DG'sVette
Thanks Mike
To Oil Leak
Old Jun 26, 2006 | 02:59 AM
FF1wms's Avatar
FF1wms
St. Jude Donor '11-'12-'13
check before ripping anything else apart.
Old Jul 6, 2006 | 10:29 PM
DG'sVette's Avatar
DG'sVette
Update:
I'm planning on putting the car up on stands this weekend to look into this deeper.
However I took a little look from the top down this evening.
On the drivers side I'm not able to see any wet spots.
On the passengers side I'm able to see some wet spots pretty far down buts its below the EGR pipe. (A little tight so its hard to see) I can not see exactly where the leak seams to be starting from.
This is the highest location that I can see of any possible oil leak.
I'll know more this weekend.
In the mean time. Any more ideas?
Old Jul 7, 2006 | 10:52 AM
madmatt9471
Use a mirror when you do the inspection's it helps out tremendously. The kind Plummer's use for looking around pipes after they are soldiered up, It has an extention on it and usually round and can extend to about 18"'s.(Use your flash light too!)It can also twist to get different angles(About a 2" mirror)
Thanks,Matt
