My '85 won't start....Help!
The engine turned over and ran for about a minute and then died.
Now when I try to start the car it turns over and catches for a second or two before it dies. Anybody have any ideas what is wrong?
All the eletronics work fine, and the engine does turn over, but it seems like it's not getting fuel. Has this happened to anyone here before, and if so where is the first place to look for a problem? The fuel pump or the line? Any help is greatly appreciated.
FEDCBA that's from left to right, on the bottom row there are six other slots, but only one has a pin..pin G, directly below pin F,
so the lay out looks like this;
FEDCBA
G. . . . .
take a wire, and jump it from the battery(positive post) to pin G, this will allow the fuel pump to run...until the wire is disconnected.Try it and report back.
The best tests are to start testing long after the last attempt to start the car. Hook up a fuel pressure gauge and observe. Next, turn the key to "On", don't crank it yet. What has happened to the fuel pressure? Did it go up? Does it stay up or does it begin to drop fairly rapidly? It should go to somewhere near 40# and hold? If so, the ECM is triggering the relay and the relay AND the pump are working. If not, there is a problem with either the pump or the relay (not likely to be the ECM). It is worth it to note, that the 2 seconds of priming can only take place after the ignition has been "Off" for at least 10 seconds. If you wish to re-energize the fuel pump via the 2 second ECM/relay power up, you need to be sure the ignition has been off for at least 10 seconds.
These steps will get you going on the trouble shooting. Get back to us with your results and we can direct you further, if necessary. The very best book in the FSM (Factory Service Manual) which is printed by Helm Inc. and available direct through that blue link. It is the ONLY manual with trouble shooting charts to track down the cause of the various codes, and for problems, exactly like this one.
RACE ON!!!
The car has been sitting for a week and this is the first time we've tried to start it since we discovered the problem.
The battery volt meter was reading about 10 volts, so I connected it to my pick-up to get it to 12.4
I then ran another wire from the positive terminal on the battery into thte car. After connecting the wire to terminal G, I heard the fuel pump activate. At least that is what I believe it was. The sound was a mechanical whir that came from behind me in the direction of the gas tank.
The car would not catch at all this time.
Unfortunatley we do not own a fuel pressure gauge so I can not run the other test that was recommended.
After searching our bacement I found the GM shop manual we got from the previous owner.
Thanks again for your help and patience.
RACE ON!!!
Just read the above, according to the wiring diagram in my 87 FSM from the power terminal behind the battery a fusible link runs to a point where it branches off, one branch goes to the oil switch, the other to the fuel pump relay...if the link blows, both lose power.And that would be the first place to trouble shoot, rather than condem both components.
Energizing terminal "G" in the ALDL does not prove the condition of the relay.
The key idea here is, BACK UP. If everything else is good , BOTH the fuel pump relay AND the oil pressure switch would have to be bad, as one backs up the other.
RACE ON!!!
RACE ON!!!
RACE ON!!!
I'm really at this point concerned with the health of your battery...and this may just turn out to be the culprit, 10 volts ain't gonna get it, sometimes even trying to jump it as you did is not sufficient.
Glad our rain is finally gone and now we're in the high 80s.
When we first encountered the problem with the car we thought that there might be moisture in the line so we kept trying to start it, and start it, and start it. This is because the car was in the middle of the driveway and blocking our other cars. After doing this for a while I think we began to wear the battery down. Without the car running the battery, obviously never recharged. In the end we had to push the car (up hill) out of the way.
A quicker way is to put your finger in the wire end and crank, but more painful.
mannnnnnnn I've been zapped good doing that ONE time
, should be able to disconnect the plug wire, put an old plug in place of it and LAY it on the manifold, you should easily be able to see it fire. RRT, do you have a little sadism in you
RACE ON!!!
Can you clarify?
Also, the reference pulses, do these come out of the module inside the distributor?
