Cap and rotor for Opti
Old Jun 25, 2006 | 08:36 AM
Glasman66's Avatar
Glasman66
Default Cap and rotor for Opti
It looks like I'm gonna be doning plugs, wires, and finding the oil leak at the timing chain cover and intake manifold. Would it be benificial to replace the cap and rotor on the Opti?
If I'm this deep should I do a electric water pump and maybe even a cam?
Is the Cam a lot more work if I'm gonna be this deep?
Old Jun 25, 2006 | 10:48 AM
SJW's Avatar
SJW
I'd swap out the entire Opti, rather than doing just the rotor/cap. Your profile suggests that yours is a '94, which would have the first-gen Opti. The first-gen OEM Opti is a POS. I'd recommend the DynaSpark, or perhaps the new MSD unit as a replacement. The Dyna has a good performance record in the field. The MSD is brand new to the market.
Re: the cam and electric water pump, your call on those. It's definitely more work, but you'll be halfway there already. Personally, I'd stick with the mechanical pump, but others will surely disagree.
Be well,
SJW
Old Jun 25, 2006 | 05:22 PM
Hotred94's Avatar
Hotred94
When I did my cam, the opti had already been replaced by the previous owner, so I kept it. Removing the timing cover is a hassle, there isn't much more to a cam change except the valve covers and springs. I thought I was in over my head when I did mine but I did it and the car fired up first try. I recommend the Hot Cam kit with rollers and springs.
The problem with changing the cam is the timing chain--it's very expensive. On 92-94 cars, the opti and water pump runs off the timing gear and you are forced to use the GM timing gear; on 95-96 the opti runs off the nose of the cam. On my 94, I didn't want to pay for the GM chain set (something like $450) so I bought a Cloyes set ($80) and machined an adapter to run the opti off of the Cloyes, then I also put in an electric water pump. It's been working perfect for a year now.
In your case, it may be best to go with the aftermarket opti setups. More money would let you convert to a 95-96 style opti but you need to get a different timing cover for that. I'm happy with the electric water pump and have had no trouble with it. It lets me circulate water with the engine turned off during cool downs, good for 5-7 horses.
Old Jun 25, 2006 | 06:34 PM
STL94LT1's Avatar
STL94LT1
I say do the cam and e water pump. You already have the gears (4.10). A camshaft would really wake your car up.
Yes, it is quite a bit more work to install a camshaft. But, well worth the effort.
Here's a great link on the camsahft install.
http://www.hashmarks.com/techtips/hot_cam.htm
To Cap and rotor for Opti
