How can I force a ECM code on my 84
Old Aug 30, 2001 | 05:11 PM
redvettefreek's Avatar
redvettefreek
Default How can I force a ECM code on my 84
Just want to verify the ECM is doing its job and figured this would be the bast test...Thanks All !
Old Aug 30, 2001 | 05:51 PM
mooibr's Avatar
mooibr
Default Re: How can I force a ECM code on my 84 (redvettefreek)
Just pull off the maf sensor, or the TPS connection and start the car. your SES light should turn on.
-=Jeff=-'s Avatar
-=Jeff=-
Disconnect the ESC wire that is used to overide the computer timing.. it is located near the Brake Booster and I believe it is a orange wire
To How can I force a ECM code on my 84
