Coolant temps
Old Jun 30, 2006 | 02:08 PM
Demonic85's Avatar
Demonic85
Default Coolant temps
As the weather has gotten warmer I saw that my engine temps have gotten higher too, like sometimes as high as 230* before the fan kicks back on. I noticed when I turn on the A/C the temps drop dramatically. Why is this?
Old Jun 30, 2006 | 02:22 PM
BADDUCK's Avatar
BADDUCK
From: One day you're a Comet...the next day you're dust... Arkansas
When you turn on the A/C the fans automatically come on. Your temp sounds about right. It's summer!
Old Jun 30, 2006 | 02:32 PM
SJW's Avatar
SJW
What you are seeing is normal, but you don't have to live with it.
If the normal operating temps leave you uncomfortable, you can lower them by installing a lower temp thermostat and kicking the cooling fans on/off at lower temps.
I did this on my '94, and I'm very happy with the results. I installed a 160* 'stat, and my primary cooling fan on/off temps are now 190*F/180*F, and the secondary fan on/off temps are 195*F/185*F.
The car now runs MUCH cooler under nearly all circumstances, and as soon as I install the new radiator that Chris May is sending me, I'm betting it'll never go above 195*F under any circumstances.
I can relax a lot more easily knowing that my cooling system has a lot more headroom before Really Bad Things begin to happen. And the lower under-hood temps should help such soft parts as hoses, gaskets, seals, etc to last longer.
Be sure that if you do this, you don't lower the fan on/off settings to the point where the fans want to run all the time. Keep the fan/off settings at least 20*F above the thermostat temp.
Be well,
SJW
Old Jun 30, 2006 | 02:37 PM
n1kki6's Avatar
n1kki6
Be well,
SJW
That seems to cool to me, what temp is your oil hitting. I wouldnt want my fans set to anything less than 210. Seems like your fans will contantly be running.
A 180 stat with the fans kicking on at 215 should keep the engine happy.
Old Jun 30, 2006 | 02:48 PM
MY85TPI's Avatar
MY85TPI
Just a sidebar, but my family has always used Water Wetter by Snap which is a coolant additive pink in color that you add and it REALLY decreases your temp up to 30 degrees. My car sits at 188 while moving and rarely sees 210 unless I am sitting for a long time on a hot day.
Old Jun 30, 2006 | 03:02 PM
rick lambert's Avatar
rick lambert
180 thermo, both fans on 200, off 185, I'm running around 180 constantly but in stop and go up to 207. Oil temps run a little higher, I'm a happy camper.
Old Jun 30, 2006 | 03:11 PM
Demonic85's Avatar
Demonic85
I realize its normal, but just found it odd that it was making it run cooler. I thought it would run hotter. With the A/C on, the temps stay around 200 or below. I just wanted to know if the A/C was a good thing for it, thanks.
Old Jun 30, 2006 | 03:15 PM
RRT vette's Avatar
RRT vette
Old Jun 30, 2006 | 03:39 PM
Lichen's Avatar
Lichen
No way is Water Wetter going to lower your temps. by 30*. I use it, but I doubt if it lowers temps by 5* max. I use a 180 t-stat with fans on at 195*, but then I live in the hot desert.
Old Jun 30, 2006 | 04:20 PM
Nico's Avatar
Nico
From: 1984 crossfire, Alhaurin de la Torre Malaga, Spain
Be well,
SJW
How does the thermostat lower the temperature? It controls the minimum temperature, not the maximum. Or do you have a device that also has outputs to control the fan?
I had to install an electronic fan control that I can adjust to make the fan kick in at the temp I like. When it fails, the normal control still works, so double security.
Old Jun 30, 2006 | 05:02 PM
SJW's Avatar
SJW
My oil temps usually hover around 20 degrees hotter than the coolant temps. The lowest my ECTs run is 171 on the coldest of days. The oil doens't always reach the boiling point of water, but it gets plenty hot enough to vaporize any moisture. In the two oil changes I've done since making the mods, I've seen zero evidence of water in the oil.
My fans do not run all the time. That was the point I tried to make in the previous post when I recommended that the lowest fan-off setting should be at least 20* higher than the 'stat temp. My 'stat opens at around 160*F. My primary cooling fan on/off settings are now 190*F/180*F. My secondary fan on/off settings are now 195*F/185*F. In hot weather, at idle or low speed, one or both fans will run, but that's what I want them to do. The ECM will shut them off at highway speed, because that's what it's programmed to do. On cooler days, the primary fan will cycle on/off at idle.
Be well,
SJW
Old Jun 30, 2006 | 05:09 PM
SJW's Avatar
SJW
The 160*F 'stat and lowered fan-on/off settings keep my LT1 running much cooler under all circumstances than was possible with the 180*F 'stat and stock fan-on/off settings. Bear in mind that it's a combination of the lower-temp 'stat and the lowered fan-on/off settings that make the difference at low speed or idle. At high speed on a cool day, the ECT runs 171 to 173*F. The highest my ECTs go on the hottest of days is 195*F (fan-on setting for secondary fan), unless I kick the A/C on, in which case it goes higher (and this should be solved when I install the new radiator that Chris May is sending me next week).
The lower 'stat temp allows the lowered fan-on/off settings to function without keeping the fans on all the time.
Be well,
SJW
Old Jul 1, 2006 | 01:58 PM
xCCTer's Avatar
xCCTer
CF JASOC Member
From: Downtown Annapolis, MD. The Future is where we all have to live. Let's not screw it up.
Default Temps
Summer in DC area around 90 most days.
When I start the engine the temp goes up to around 193, and then the thermostat opens (190). Next the temp drops to around 183-4 as the coolant is free to flow through the radiator. It then slowly climbs up to 194-5 again and stays there unless I'm stuck in traffic.
Traffic gets me a slow climb to 228 at which point the main cooling fan turns on and quickly brings the temp back to around 213, then it cycles off until 228 again and so on...
I have never seen my aux cooling fan (in front of condenser) turn on at all. I have tested it and the associated relay (on fan shroud) and the temperature switch (left side head), and they all work fine. Haven't figured out yet at what temp it should turn on.
If I'm in traffic with the a/c on, this runs the main cooling fan and it hovers around 216-7 as the fan will not cycle off with the a/c on.
To Coolant temps
