Tow Hooks
With the car so low to the ground, it appears that any chain (leading to the front of the car---the apparent direction that the car would be towed or dragged up on a flatbed) attached to the front tow holes can't help but put enormous upward force on the rear portion of the lower arm.
Not only would I like some clarification on where I may be wrong, but I recently bought a 18-foot car-hauler and have started to wonder where to attach and what pattern to use for the haul-down straps I intend to use.
Note to the Moderator: If this post should be over in the racing section, go ahead and move it.
I wrote that.
To start with, most flat beds use a steel cable, not a chain.
I suspect that if this would cause a problem for the car, GM would have relocated them. I only can report what is given to me, in this case, it's the fixed location of the tow hooks.
To be honest, I doubt it would hurt much, the tension would be right where the lower control arms attach to the chassis, their strongest point.
As for haul straps, I would attach them to the tow hooks, or, wrap them around the tires.
In other words, 1 strap would attach to the tow hook by the driver's foot well and attach to the trailer close to where the rear passenger tire would be. The other front strap would attach to the tow hook by the passenger foot well and to the trailer near where the driver's side rear tire would be.
The straps that attach to the rear of the car would be attached to the trailer near the front tires.
I would also assume that blocking the tires is a given, as well as having an automatic in neutral (instead of park) to eliminate damage to the parking pawl while the car is rocking back & forth during the trip.
I haven't towed the car yet, so I'm looking for advice from those who know.
