GMPP--Dana 3.45 gears???
Old Jul 2, 2006 | 06:08 AM
JTHVETTE's Avatar
JTHVETTE
Default GMPP--Dana 3.45 gears???
Did or does GM produce 3.45 ring and pinion for a Dana 36 ? If they have, what are the part numbers?
Thanks,
JTHVETTE
Old Jul 2, 2006 | 07:15 AM
93 ragtop's Avatar
93 ragtop
I dont believe GM ever produced anything other then the 2.59 through 3.07 gears. There were a few other ratios in between those two. You can get a 3.54 , 3.73, and a 3.75 for the dana 36 in aftermarket parts but not GM.
The 3.45 was a dana 44 gear.
Old Jul 2, 2006 | 08:59 AM
BADDUCK's Avatar
BADDUCK
From: One day you're a Comet...the next day you're dust... Arkansas
3.54 is a stock GM gear in the Dana 44. I have them in my early 1989 Z51 coupe.
Old Jul 2, 2006 | 09:09 AM
JTHVETTE's Avatar
JTHVETTE
Default 3.45 Gears????
The reason I am asking this is because there is set of gears on Ebay that the seller is saying they fit a Dana 36 .(#28001736410)
If that was correct, I would bid on them. From what I understand they are for a Dana 44. Check it out and let me know.
Thanks,
JTHVETTE
Old Jul 2, 2006 | 09:28 AM
93 ragtop's Avatar
93 ragtop
But the post was asking about a dana 36, not a dana 44.
Old Jul 2, 2006 | 09:32 AM
BADDUCK's Avatar
BADDUCK
I know, it was just an add on because your last sentence addressed the Dana 44. I thought I would point that out. 3.54 IS a GM gear in the 44.
Old Jul 2, 2006 | 12:50 PM
CFI-EFI's Avatar
CFI-EFI
GM supplied (made by Dana) both 3.45 and 3.54 gears for the Dana 44. The lowest factory gears for the 36, was 3.31:1. There are aftermarket 3.54 gears for the Dana 36, but no 3.45's for the 36, that *I* have ever heard of.
RACE ON!!!
Old Jul 2, 2006 | 01:19 PM
CentralCoaster's Avatar
CentralCoaster
From: San Diego , CA Double Yellow DirtBags 1985..Z51..6-speed
Yeah, Dana produced the 3.45 D44s for GM, but I don't know of any produced since then. The aftermarket does not offer any 3.45s for either rear end, as far as I know. I had to get my 3.45s used.
Old Jul 2, 2006 | 02:25 PM
BADDUCK's Avatar
BADDUCK
I don't know about you guys but I'd be hard pressed to tell the difference in a 3.45 and a 3.54 on the street.
Old Jul 2, 2006 | 02:32 PM
tobijohn's Avatar
tobijohn
Bench Racer
St. Jude '03 thru 14,'25
Originally Posted by CFI-EFI
...The lowest factory gears for the 36, was 3.31:1. There are aftermarket 3.54 gears for the Dana 36, but no 3.45's for the 36, that *I* have ever heard of.
RACE ON!!!
The 3.31 was an option in the 84s only. Believe it or not, you can still get them. Motive has them listed in their catalog (http://www.motivegear.com/pages/cata...ffCat_2001.pdf - page 14). I'm assuming though that these are for the 3.x series rears...
Old Jul 2, 2006 | 02:38 PM
93 ragtop's Avatar
93 ragtop
Whats a matter? Your butt-o-meter not that sensitive?
Old Jul 2, 2006 | 02:47 PM
BADDUCK's Avatar
BADDUCK
It spends too much time on that shakin' *** Harley!
Old Jul 2, 2006 | 03:07 PM
93 ragtop's Avatar
93 ragtop
OK so you have 2 cool rides
To GMPP--Dana 3.45 gears???
