Acceleration issue
Old Jul 2, 2006 | 09:59 PM
Skrud13's Avatar
Skrud13
Default Acceleration issue
On my 88 automatic, when I accelerate (full throttle of course) as soon as the wheels break lose and the RPM start winding up, the engine bogs out and loses power then surges back up and bogs again. It keeps this up until I let off the gas. Could this be a fuel filter issue or is it something else?
Old Jul 2, 2006 | 11:09 PM
kopbet89c4's Avatar
kopbet89c4
Might be that the fuel pump isn't keeping up. I'd check your fuel pressure at WOT.
Old Jul 3, 2006 | 10:36 AM
rick lambert's Avatar
rick lambert
Check out your TPS too.
Old Jul 3, 2006 | 11:22 AM
MikeC4's Avatar
MikeC4
The "bogs and looses power" sounds like a clogged cat, but the "surges back up" is not usually associated with a bad cat...but you never know...just something to keep in mind.
Old Jul 3, 2006 | 11:52 AM
CFI-EFI's Avatar
CFI-EFI
More than likely it is a fuel delivery problem. It could be a filter past due for replacement, a bent or kinked fuel line, a pump on the way out... As the first response said, check it out at WOT, with a fuel pressure gauge attached. If the pressure drops, start trouble shooting the fuel system. If not, move on.
RACE ON!!!
Old Jul 3, 2006 | 12:01 PM
z28cp's Avatar
z28cp
ASR??
DaveZ.
Old Jul 3, 2006 | 12:17 PM
fsr402's Avatar
fsr402
Cruise-In VI Veteran
Cruise-In VII Veteran
St. Jude Donor '06
Originally Posted by z28cp
ASR??
DaveZ.
I don't think the 88 has it.
To Acceleration issue
