ohm testing injectors
Old Jul 3, 2006 | 12:11 AM
RetroTA's Avatar
RetroTA
Default ohm testing injectors
Someone once told me you can test injectors with an ohm meter, I believe they should be around 10 to 14 ohms. Does this ring a bell to anyone.
Old Jul 3, 2006 | 12:45 AM
Aggravated4life's Avatar
Aggravated4life
Cruise-In II Veteran
Yep,but test them cold then hot...see if theres a big difference doing the test this way.
Old Jul 3, 2006 | 09:51 AM
rick lambert's Avatar
rick lambert
16 Ohms, what you're really looking for is to make sure they all ohm within +- about 1 ohm. As suggested, do it both hot and cold. This is going to tell you the health of the injector coils. You may want to do a fuel pressure test also if you suspect injector problems.
Old Jul 3, 2006 | 10:33 AM
steve40th's Avatar
steve40th
St. Jude Donor '03 & '05
Do them hot and cold, to see if any are breaking down. My Ford SVO 30#'s were 14.9 ohms.
To ohm testing injectors
