X-Pipe for LT1 resonator replacement?
Old Aug 31, 2001 | 07:12 PM
LT1GMC's Avatar
LT1GMC
Default X-Pipe for LT1 resonator replacement?
Does anyone make a bolt in x-pipe to replace the resonator section on the LT1 Vettes? Seems like that would be a place to gain a bit since the resonator does not connect between the 2 sides, therefore no h-pipe or x-pipe type torque advantage.
Old Sep 1, 2001 | 11:04 AM
jimbjr's Avatar
jimbjr
Default Re: X-Pipe for LT1 resonator replacement? (LT1GMC)
Installed a 3" from Dr Gas. Believe it or not it made a difference. Not anything that I felt in the seat of the pants but saw a big change while racing my brother-in-laws 430hp mustang.
The tone of the exhaust moved a little higher as well, very little.
Jim
Old Sep 1, 2001 | 01:06 PM
RVY's Avatar
RVY
Default Re: X-Pipe for LT1 resonator replacement? (jimbjr)
Your not pushing enough horsepower to warrant the added noise. With 571 hp@the rear wheels I took mine off
after 55miles The noise was unbearable. If you want to spend your money and suffer---your call.
To X-Pipe for LT1 resonator replacement?
