Detaching cruse and throttle cable-How?
Old Aug 31, 2001 | 07:51 PM
Frank C's Avatar
Frank C
Default Detaching cruse and throttle cable-How?
OK, this might seem dumb but how do you detach the cruse and throttle cables from the throttle body? I assume it's one unit but I don't seem to see how (91L98). Thought I'd better know how before I drain the coolant in preparation to remove the throttle body and I'm unable to find this procedure in the GM service manual. While I'm at it, is it just replace the water in the upper tank after through? What's with the bleeder lines? Thanks, Frank
Old Aug 31, 2001 | 07:56 PM
Kale's Avatar
Kale
Default Re: Detaching cruse and throttle cable-How? (Frank C)
The cruise cable is a little washer with a lip. pull the lip up and slide it off. Be careful, you will PROBABLY lose it in your engine if you are not.
The throttle cable is clipped on
hold the linkage in place, and slide the attaching bit TOWARD the front of the car, DONT force it, it will pop off.
IM me if you need further help.
