C4 Engine Mounts
Old Jul 4, 2006 | 04:08 PM
CharlieLed's Avatar
CharlieLed
Default C4 Engine Mounts
I have seen some C4 IFS crossmembers with raised engine stands, ala F-bodies, and some that have flat pads that look more like the C5 mounts. Is this configuration dependent on the year...the later C4's I have seen have the flat pad, do the early C4's have the raised stands? The reason I ask is because I am looking at an LS6 conversion and the flat pad mounting looks to be exactly the same as the C5 mounts...could it be that easy?
