New TPS
Old Jul 5, 2006 | 11:33 AM
KDuniverse's Avatar
KDuniverse
Default New TPS
Anyone know how to "relearn" without the Tech 1? Is it at all possible, or do I need to bring it to a shop?
Old Jul 5, 2006 | 12:14 PM
JustForFun's Avatar
JustForFun
Can Reset It Using A Volt Meter
Old Jul 5, 2006 | 02:01 PM
KDuniverse's Avatar
KDuniverse
how is that done?
Old Jul 5, 2006 | 04:05 PM
fxgrnd38's Avatar
fxgrnd38
ttt
Old Jul 5, 2006 | 04:32 PM
L71Maynard's Avatar
L71Maynard
If you have an LTx like me then you probably can't use this advice since TPS is not adjustable. I would like to know if there is anyway to do the relearn on an LTx car without going to the dealer as well.
Dave
Old Jul 5, 2006 | 05:41 PM
KDuniverse's Avatar
KDuniverse
nobody's had any experience with the TPS???
Old Jul 5, 2006 | 07:36 PM
MikeC4's Avatar
MikeC4
To my knowledge, there is no reset procedure for the TPS. Each time the engine starts, the PCM records the voltage from the TPS and assigns this voltage value as 0% throttle position(ie idle). Normal voltage at idle should be approximately 640mV. As you throttle up, this voltage will increase. WOT should measure about 4V + idle voltage = 4.64V.
Not much to it, the TPS sensor is a simple mechanical varistor....now some folks will adjust their TPS setting by enlarging the 2 mounting holes in the TPS unit, so that it can move in a 'circular' fashion on the throttle shaft, whereby the TPS idle voltage cab be modified. While others will just purchase an adjustable TPS sensor.
FYI, There is no power gain by raising your idle setting voltage. What does change is when the PCM will switch from MAF/MAP/O2 to "enrichment mode". Not sure I am explaining this intelegably, so look at this pic, where 2 idle setting voltages are displayed...heavy footed acceleration, you couldn't tell the difference, moderate acceleration, and the lower TPS graph will kick into fuel hog mode sooner...but who cares about moderate acceleration anywho?????
Old Jul 5, 2006 | 08:24 PM
CFI-EFI's Avatar
CFI-EFI
A YEAR would be nice. 1990 and up are nonadjustable and the ECM accepts the lowest reading, within a range, as closed throttle. Ultra late C4s may be somewhat different. For 1989 and earlier, adjust it to spec. In either case, the TPS doesn't need to, and can't learn.
RACE ON!!!
Old Jul 5, 2006 | 09:27 PM
KDuniverse's Avatar
KDuniverse
I put the TPS on, and no lights came on. It idled great, and ran it for 20min or so. I checked the codes, and it still shows H64. How do I clear out that old code? If it was new, there woudln't be an H, would there be?
Old Jul 5, 2006 | 09:35 PM
MikeC4's Avatar
MikeC4
disconnect you negative battery post for 30 seconds, then re-attach. This will clear out any History codes.
Old Jul 5, 2006 | 09:37 PM
KDuniverse's Avatar
KDuniverse
disconnected for 10min, nothing.
Old Jul 5, 2006 | 09:44 PM
MikeC4's Avatar
MikeC4
Well that sux! Inspect the male and female connector for bent pin or pushed out recepticle. Make sure you have good contact on all pins. I can't remember, is it a 3 or 4 pin connector. One pin will be your 5V reference, and 1 pin will be your Ground. Is you TPS adjustable kind or non-adjustable?
Old Jul 5, 2006 | 09:45 PM
KDuniverse's Avatar
KDuniverse
GM replacement of what was on there.
Old Jul 5, 2006 | 09:55 PM
Scooter 94's Avatar
Scooter 94
The way I read my '94 FSM, it's the ECM that has to learn the specific voltage of a newly installed TPS. Precise throttle position is required for proper operation of ASR (traction control).
So my question is the same as the original poster's (how's it done without the Tech 1), and also...is it one of those steps you could just skip with no ill effects in real world use?
btw...94 TPS is non-adjustable
Old Jul 5, 2006 | 10:06 PM
MikeC4's Avatar
MikeC4
it is a simple sensor to test if you have a digital voltmeter. It's best if you have a TPS "test harness" to check voltages(otherwise you have to make small piercing holes through the wire insulation to measure stuff). I can't remember the procedure, but can look it up if you want...I have the test harness and instructions out in the garage somewhere.....
http://www.ecklers.com/product.asp?p...&dept%5Fid=119
Old Jul 5, 2006 | 10:12 PM
MikeC4's Avatar
MikeC4
Correct, the PCM records and stores the voltage value at idle(s/b about 600mv). The TPS is just a variable resistor(voltage divider circuit) with no active components inside. So what would a Tech 1 be needed for? There is no programming of the TPS at all.
Old Jul 5, 2006 | 10:22 PM
Scooter 94's Avatar
Scooter 94
From '94 FSM Book 2:
The Electronic Brake and Traction Control Module (EBTCM) must learn the TP sensor idle position voltage with new component(s) installed. This is necessary to ensure effective engine torque reduction during ASR events. The procedure requires a Tech 1 scan tool or CAMS unit and will be described using a Tech 1.
A. Ignition off.
B. Connect Tech 1
C. Ignition on
D. Follow menus to reach ABS/ASR features
E. Slect "F5:TPSENSR LRN"
F Press (up arrow) to begin learn procedure
G. Wait for Tech 1 to indicate complete
H. Ignition off.
I. Disconnect Tech 1
To me, it reads like the EBTCM has to learn something specific about that particular new TPS. There's no adjustment of the TPS and the TPS doesn't "do" anything other than send its signal to the EBTCM.
To New TPS
Old Jul 5, 2006 | 10:48 PM
MikeC4's Avatar
MikeC4
Scooter 94- Thank you for the clarification, because I was starting to get confused with this thread. The EBTCM was not mentioned, and usually is overlooked. I suspect that the EBTCM lacks circuitry(comparators) to determine/store the TPS idle voltage. I was referring to the PCM and its ability to learn the TPS idle voltage.
Old Jul 6, 2006 | 09:44 AM
KDuniverse's Avatar
KDuniverse
Ok, so there is a learn process for the EBTCM? So I do need the Tech 1.
Also, about the history code. If it was still throwing the code, the light would come on, and it would run like it did. The pins aren't bent.
Old Jul 6, 2006 | 01:56 PM
KDuniverse's Avatar
KDuniverse
ttt
