Replacement Dash bulbs
Old Sep 1, 2001 | 01:00 AM
tsquare's Avatar
tsquare
Default Replacement Dash bulbs
Can I get replacement bulbs for the gauge cluster,speedo,and rpm from an auto parts store?Reason being, I just shelled out $75. to mad for some new bulbs and it just dawned on me that there might be a cheaper alternative
Old Sep 1, 2001 | 02:45 AM
Rick86's Avatar
Rick86
Default Re: Replacement Dash bulbs (tsquare)
I bought a sylvania 882 for one of the center light on my gauge cluster, still haven't installed but paid about $7-8 at Kragen autoparts.
Old Sep 1, 2001 | 07:36 AM
C4RAG's Avatar
C4RAG
194 bulbs
http://forums.corvetteforum.com/zerothread?id=133836
Old Sep 1, 2001 | 10:37 AM
ski_dwn_it's Avatar
0ski_dwn_it
Former Vendor
Default Re: Replacement Dash bulbs (C4RAG)
Pull the front bezzel (sp) off and you will see the shinny metal covers over the lights. Pop them off adn grap the light with a small set of pliers. Gently pull straight out and take the pulled bulbs to Autozone, ect. Total cost to do mine was ~$6.00. If I would have known how easy it was to do I would have changed them 2 years ago. Everything works perfect now! Good luck.
Old Sep 1, 2001 | 02:25 PM
Jay Axson's Avatar
Jay Axson
$75.00 USD for light bulbs? :cry :cry :cry :bb :bb
Cancel the order. Refuse shipment. Don't pay!
Old Sep 1, 2001 | 04:08 PM
Juliet's Avatar
Juliet
Default Re: Replacement Dash bulbs (ski_dwn_it)
Is getting the front bezel off really as easy as just taking out the half dozen or so screws? This is on my list.... top of the list infact. I bought a new bezel to replace the original one with the cracked corners from some Bubba overtightening the screws and cracking the plastic.
Old Sep 2, 2001 | 10:41 AM
6spd89's Avatar
6spd89
Cruise-In II Veteran
Walmart has your bulbs!!I believe someone said 194!!!
Pull them from the front with needle nose,just do not touch the bulbs
with your fingers(oil).Easy money.
Matt
Old Sep 2, 2001 | 05:17 PM
Steve86's Avatar
Steve86
Default Re: Replacement Dash bulbs (Juliet)
Juliet,
It's just that easy. Take all the screws out, tilt the steering wheel down to its lowest level, unscrew your tilt lever and pull the bezel. I used needlenose pliers with masking tape around the ends to pull the bulbs, then a drinking straw to get the bulbs started. Once they were in place I gently pushed the bulbs the rest of the way into the base with my fingers. I wear rubber gloves to keep skin oils off the bulbs. It's a much easier project than it sounds, and your dash will look 1000pct better with full lighting and a new bezel. Good luck, Steve
To Replacement Dash bulbs
