1984 Metal Fuel Lines
Old Jul 5, 2006 | 04:32 PM
440man's Avatar
440man
Default 1984 Metal Fuel Lines
Has anyone had to replace these on your car? Does anyone know of a tech article anywhere? Does anyone know the exact diameter of the lines?
Old Jul 5, 2006 | 05:04 PM
Bruce Witherspoon's Avatar
Bruce Witherspoon
Are yours bad and are you in need?
Old Jul 5, 2006 | 06:13 PM
440man's Avatar
440man
The feed from the tank is bad, hole rusted right under the passenger compartment, and YES I'm in bad need Anybody??
Old Jul 5, 2006 | 06:43 PM
Ramanstud's Avatar
Ramanstud
You can sometimes buy pre-bent or salvage - I wouldn't buy salvage fuel lines if my life depended on it and they were on sale.
You can bend your own by buying the diameter you prefer and then getting a $10 bender and a $10 double flare tool all at the local parts stores, but practice a bit and you'll have to peice it together due to the limited length of tubing you can get.
OR you can spend 10x what it's worth and run braided steel line all the way from the tank to the fuel rails. Looks cool, lasts damn near forever and is much easier to route (because it flexes) but costs a fortune.
Old Jul 5, 2006 | 07:40 PM
CFI-EFI's Avatar
CFI-EFI
Don't sweat the "exact diameter". Except at the throttle bodies all the connections are a hose, slip fitted over the steel tubing with a hose clamp. For a patch section, a double flare might be nice, but you are only dealing with a spec with a max of 13 psi fuel pressure. I don't think you could go wrong with the factory, hose over tubing, style of connection. A tubing diameter of 3/8" will work perfectly, for the supply side, 5/16" for the return.
RACE ON!!!
Old Jul 5, 2006 | 10:21 PM
440man's Avatar
440man
Thanks for the help fellas! I just bought the Vette (my 1st) a couple weeks ago and trying to get it going so I can move it around. I've got a lot of work to do on it. It needs paint & interior. Only has 72,000 and is bone stock. Nothing has ever been touched except for maintenance. It just suffers from the neglect of being left outdoors and not driven for the last 8 years. I pumped 19 gallons of water out of the tank when I got it home.
Sure is nice to have a resource like this with folks willing to help you out.
Thanks Again!!
Old Jul 5, 2006 | 10:30 PM
Grease Monkey's Avatar
Grease Monkey
From: Hampton, VA Yea, i'm a redneck... but you love it
Cruise-In 8-9 Veteran
aka/Trunk Monkey/Banned For Life/Corvette For Life
its east to get it and bend it yourself, dont pay the extra for the pre-bent
To 1984 Metal Fuel Lines
