Brown Goo In Coolant
Old Jul 5, 2006 | 05:16 PM
jimmers's Avatar
jimmers
Default Brown Goo In Coolant
The other day I checked my coolant level and noticed a bunch of sticky brown goo around the reservoir cap. I cleaned it out and have been checking daily to see if it comes back, but it hasn't. I had the coolant flushed out from GM last year just after I got the car. Besides new coolant, they put a can of bars leak in saying its best because of the age of the car. Would the bars leak do that? I'm going to flush the coolant to be safe, but should I be concerned? I've heard of brown sludge, but never a sticky goo. Thanks
Old Jul 5, 2006 | 05:18 PM
STL94LT1's Avatar
STL94LT1
Sounds like the Barrs-Leak. If the car isn't overheating, I wouldn't be concerned.
Old Jul 5, 2006 | 05:25 PM
jimmers's Avatar
jimmers
The car temps are normal. I've never used Barrs-Leak(thanks for the spelling correction) so I dont know what it looks like.
Old Jul 5, 2006 | 05:29 PM
Blownfuel1's Avatar
Blownfuel1
You do now! I think Brown Goo is the best (G-rated) description I've ever heard for it! Smells real nice too!
Old Jul 5, 2006 | 05:31 PM
z28cp's Avatar
z28cp
On my 94, the FSM says that when you change the anti-freeze, you are supposed to add 6 of the GM stop leak pellets when you refill. Barrs has the same pellets available at the auto parts stores. This could very well be what you are seeing.
DaveZ.
Old Jul 5, 2006 | 05:33 PM
jimmers's Avatar
jimmers
I had to make it appropriate for the forum. Now when I first saw it another thing came to mind.......
Old Jul 5, 2006 | 05:55 PM
vader86's Avatar
vader86
If you added anti-leak stuff, that goo will be there.
Thats why I dont ever add the stuff.
Old Jul 5, 2006 | 08:15 PM
madmatt9471's Avatar
madmatt9471
From: Palmdale, Ca----- 2009 Cyber Gray 4LT A6 F55 452 RWHP 422 RWTQ- RIP 1998 C5 734 RWHP & 585 RWTQ-----
Should be Brown-POO! Seen some in mine before I did a total sytem flush and got rid of that Cr..P used a BABY WIPE got some on my finger you know!!!
Thanks,Matt
Old Jul 6, 2006 | 12:10 AM
CharlieLed's Avatar
CharlieLed
I can't believe a GM dealer would add Barrs-Leak just because of the age of the car. If that were me I'd scratch that dealer's name off my reputable dealer list. Barrs-Leak is for backyard mechanics who can't or won't repair a coolant leak correctly...I would never add it to my cooling system unless it was an emergency...and then it would get flushed out at the first opportunity. That brown slime on your radiator cap is foaming all around your engine right now, keeping the coolant from doing its job most efficiently. Ugh...
Old Jul 6, 2006 | 12:59 AM
Steel Breeze's Avatar
Steel Breeze
Old Jul 6, 2006 | 01:20 AM
92Beast's Avatar
92Beast
My coolant reservoir was coated in this brown goo. I tried to wash it out with soap and water with rocks for agitation since there is not way to get anything in side it. Did not touch it. Finally went to white gas and rocks for agitataion. Cut it like a charm. Washed with Dawn again and presto like new inside.
Old Jul 6, 2006 | 08:14 AM
onedef92's Avatar
onedef92
Cruise-In IV Veteran
Cruise-In VI Veteran
Cruise-In VII Veteran
Cruise-In VIII Veteran
I've heard GM and other manufacturers add either the brown radiator pellets or the Barr's Stop Leak at the factory.
Old Jul 6, 2006 | 08:18 AM
LD85's Avatar
LD85
I did this once, I added the Brown Barrs pellets, the radiator would oooze small foam bubbles, so I back flushed the rad 2-3 times with a garden hose, then added distilled water and coolant.
Old Jul 6, 2006 | 08:47 AM
runner140*'s Avatar
runner140*
Think it might be a good time for a complete cooling system flush?
Old Jul 6, 2006 | 09:08 AM
c4cruiser's Avatar
c4cruiser
DaveZ.
GM issued a service bulletin to the dealerships a few years ago telling the techs to discontinue the use of the coolant sealing tabs in aluminum radiators. Apparently the tabs would react to certain brands of coolant and clog up the tubes in the radiator. Sometimes the tabs would not dissolve completely and pieces would clog up tubes.
Unless there is a leak in the cooling system that needs to be stopped until repairs are made, I would not use any sort of stop leak stuff added to fresh coolant.
Even if there is a leak, one old-school trick for leaks is to empty a can of pepper into the coolant. The pepper expands to fill any leaks and easily flushes out when the system is flushed.
Old Jul 6, 2006 | 11:29 AM
STL94LT1's Avatar
STL94LT1
I work for GM, and we haven't use the coolant pellets since 1992. At least at my plant where we build the full size van.
Old Jul 6, 2006 | 04:47 PM
jimmers's Avatar
jimmers
Thats what the guy told me at the time because I asked about them using it.
To Brown Goo In Coolant
Old Jul 7, 2006 | 12:27 PM
onedef92's Avatar
onedef92
This was for the aluminum block and heads GM engines, Vettes and Caddy's too.
Old Jul 7, 2006 | 05:21 PM
86z51-4+3's Avatar
86z51-4+3
Old Jul 7, 2006 | 05:52 PM
comp's Avatar
comp
have seen mixing anti-freez go to brown goo,,,, it ate threw some cooling system parts on a 4.6 sohc Ford
