Nose emblem question
Old Jul 5, 2006 | 11:35 PM
jimmers's Avatar
jimmers
Default Nose emblem question
I recieved both of my emblems today and am curious about the nose emblem. The gas door one has 2 bolts and double sided tape. The nose emblem has nothing. Is it just stuck on with double sided tape aswell? Thanks
Old Jul 5, 2006 | 11:45 PM
scorp508's Avatar
scorp508
No tape on the nose emblem, just 2 self-tapping push nuts.
Old Jul 5, 2006 | 11:57 PM
jimmers's Avatar
jimmers
How do they work exactly? Do I just push it on and thats it?
Old Jul 6, 2006 | 12:01 AM
LilR3dCorvette's Avatar
LilR3dCorvette
St: Jude Donor '10
The previous owner of my '94 put different emblems on the car than what came on the car (has actual chrome emblems instead of the black). I just had some hood paint work done and the painter said that it was most likely that I would need to replace the emblem.
Lo and behold, the emblem I have had no double sided tape and it instead actually screwed into the hood. So they were able to re-use it. I think I like that concept better. I have another vette that I want to use the same exact emblems on...I wonder where I can get the same exact set? Sorry for the hijack, but any ideas appreciated...
Old Jul 6, 2006 | 01:12 AM
goldeneye_vet's Avatar
goldeneye_vet
No they screw on just like the back emblem but you'll be lucky to get 2 full turns out of it as they cinch the nut to the hood. Be CAREFUL!!! Let me emphasize that part that you don't lose them otherwise they are gone for good in that little cavity. Put a little tape or something sticky like a booger or some sealant inside your socket when you go to tighten them on so that they stay on the socket and don't get lost. Take your time and you'll be fine. I lost one of the nuts and had to improvise. Good luck!
Old Jul 6, 2006 | 01:24 AM
JrRifleCoach's Avatar
JrRifleCoach
From: Freedom is never more than one generation away from extinction.
St. Jude '03 thru '24
If not secured with the nuts, the front emblem will depart the car at 97 MPH! This has been confirmed.....twice.
Old Jul 6, 2006 | 02:34 AM
skateparkdave's Avatar
skateparkdave
St. Jude Donor '05-'06
They are hidden up in these holes just below the Bowling Green badge under the hood.
Use some good two sided tape in a small socket because if you drop the nuts they're gone. You'll see what I mean.
Old Jul 6, 2006 | 03:03 AM
CentralCoaster's Avatar
CentralCoaster
From: San Diego , CA Double Yellow DirtBags 1985..Z51..6-speed
I bought GM emblems for my 85. Both were made out of cheapy pot metal.
The front one had two pegs that the speed nuts would thread onto. No adhesive though.
The rear one had the sticky foam adhesive and two threaded parts the nuts screwed onto.
These both matched the original ones that came on the car.
Old Jul 6, 2006 | 03:32 AM
VenkmanP's Avatar
VenkmanP
My originals and GM replacements all had tape - front and rear.
Old Jul 6, 2006 | 07:35 AM
corvette-pilot's Avatar
corvette-pilot
When I replaced them on my 94 the front and rear both used tape and nuts. When I put the new ones on I just used the nuts so I can take them off if needed to clean/wax around them. Took me forever to get the old tape off !
Old Jul 6, 2006 | 09:27 AM
jimmers's Avatar
jimmers
Thanks everyone! I'm going to put them on today!
Old Jul 6, 2006 | 10:04 AM
jimmers's Avatar
jimmers
Well there werent any nuts on the emblem I took off, just tape. Would an autoparts store sell them? What size do I need?
Old Jul 6, 2006 | 12:30 PM
jimmers's Avatar
jimmers
Nevermind guys I actually found them. They must have fallen in between in the hood when I pulled the emblem off.
Old Jul 6, 2006 | 01:04 PM
Red Tornado's Avatar
Red Tornado
when i replaced mine, i removed any 2-sided tape on the new emblems. that way, each time i wax the car, i remove the emblems with ease..........this alleviates the aggravating removal of wax at the emblem area and leaves a nice clean result every time.
Old Jul 6, 2006 | 02:31 PM
VenkmanP's Avatar
VenkmanP
I just left the backing on the tape so it isn't stuck down.
Old Jul 6, 2006 | 04:00 PM
skateparkdave
Ahhhhh, hence my instructions.
Now you see what I meant. If you found them you got lucky.
Old Jul 6, 2006 | 04:37 PM
jimmers's Avatar
jimmers
I think they were loose to begin with because I didnt even pull hard!!
But yes I got lucky, they fell into the air filter housing.
To Nose emblem question
