LT-1 engine mod vs emissions
Old Jul 6, 2006 | 11:45 AM
BlueMonster94's Avatar
BlueMonster94
Default LT-1 engine mod vs emissions
One day I'd like to have some mods done to my LT-1 engine now residing in my 1994 Vette. I've been told by a friend that modified engines won't pass emission tests. I live in Greenville, TX where emission tests are not done YET. Oh, when I get my new plates I will put both on my car.
Old Jul 6, 2006 | 12:00 PM
STL94LT1's Avatar
STL94LT1
My 94 is extensively modded and will still pass emissions testing. The car has ported heads, 224/230 605/622 camshaft, long tube headers, high flow cats, 52mm TB, e. water pump, and several other small mods, and will still pass Missouri's emissions testing.
It's all in the tune.
-Mike
Old Jul 6, 2006 | 12:26 PM
BlueMonster94
-Mike
Thank you very much. When it is time for an engine rebuild, I will do some mods.
Old Jul 6, 2006 | 01:13 PM
BlueMonster94
-Mike
What did your mods do for your car? HP? Torque? Speed? ET? Gas mileage?
Old Jul 6, 2006 | 01:26 PM
STL94LT1's Avatar
STL94LT1
Right now it's making 370+rwhp/345rwtq, has ran 12.3x @115-116mph with the old camshaft-has 20 more rwhp now. So, should run a little faster. Best of all it still gets 26-28 mph on the highway. Oh, the car also has 4.10 gears.
Old Jul 6, 2006 | 01:49 PM
BlueMonster94
Not bad. And the engine remains naturally aspirated, eh?
Old Jul 6, 2006 | 06:07 PM
93 ragtop's Avatar
93 ragtop
Mine is modded and passes. Just make sure you get someone who knows how to tune. There are some who charge for it but dont know squat. See my signature for mods and performance
Old Jul 6, 2006 | 07:52 PM
FELNGR8's Avatar
FELNGR8
I have the 218/228 LT4 Hotcam kit, headers, and custoim exhaust with Random Tech cats. It passed emissions with no tune changes as soon as I had the cats on the car. I only needed a tune after putting on a larger throttle body, and then it was for drivability.
The 94 PCM can adjust to a relatively big hydraulic cam and pass emissions as long as you have good cats on the car.
The 92-93 cars are speed density and require tuning for any major changes. Your 94 will be good to go as long as you stay within reasonable limits on mods.
Old Jul 6, 2006 | 09:56 PM
BlueMonster94
Thanks for the info.
Old Jul 7, 2006 | 12:48 AM
JD'S WHITE 93's Avatar
JD'S WHITE 93
I checked your car out. Very nice and I saw it's an automatic. The first performance mods I did to mine were 3.73 rear gears and a convertor.
No effect on emissions and with just those two mods alone and a set of real rear tires I went high 12's. Find out what gears your car has in it now. If it's got the 2.59 rears as many did you won't believe the difference the gears and convertor will make. Check under the lid of your center console for the rpo code for your rear axel. GM1 is the code for the 2.59's
Old Jul 7, 2006 | 12:44 PM
BlueMonster94
I don't have the car where I can get to it. Truth be told it is in the local Ford garage having a tune up and other stuff being done to it. Where I live, you don't go to the Chevy place unless you have no other choice. I used to own a Taurus SHO (gulp) and this Ford house did a good job with some big time maintenance work. I trust them over a greasy garage or the Chevy house. Back to topic! As I recall, my car has a performance rear end, whatever that is. I saw something about that option on my window sticker.
Old Jul 7, 2006 | 07:30 PM
bobmic93's Avatar
bobmic93
I think those readings on the dash might be off by 10 mph or so. Honda's get those kind of readings. With those mods of yours you might see 20 to gallon. Just being realistic with ya!
Old Jul 7, 2006 | 07:35 PM
STL94LT1's Avatar
STL94LT1
With the M6 and 4.10's, the car is still only turning 1800 rpms at 70mph. I just filled up, will check the gas mileage when I refill.
Old Jul 7, 2006 | 07:56 PM
Draven's Avatar
Draven
St. Jude Donor '14
I get 25-26 for long drives.
Old Jul 7, 2006 | 09:50 PM
JD'S WHITE 93
You should then have a 3.07 rear. Swap it for a 3.73 and you'll be very happy.
Old Jul 8, 2006 | 10:02 AM
BlueMonster94
To tell ya the truth, I'm quite happy with the car now with the exception of those bugs that the Ford house in Greenville is removing from the car. Before any work has been done to my car, it was getting 25.5 mpg highway on a trip from Greenville to Tulsa. BTW, I do NOT rely on the onboard MPG data. I still figure my MPG the old fashion way, total miles divided by total gallons pumped after the trip. My next question would be how would the 3.73 rear end impact performance and MPG?
Old Jul 8, 2006 | 10:25 AM
JD'S WHITE 93
Mr. Mojo is the guy to talk to, he has a 93 that is box stock except for 3.73 gears and a convertor. His car runs 12.50's with just those two changes. I did a little more than just gears and a convertor and I get 16 in the city but I drive it agresively. I don't know the mileage on the highway I think it's 20 or 21
Old Jul 8, 2006 | 11:22 AM
MTVette's Avatar
MTVette
My modded 92 A4 still passes emissions - see mods below. As for gas mielage, I get 15/22 city/hwy.
To LT-1 engine mod vs emissions
