Rear end goes every direction under Accel/deccel !!!
Old Jul 6, 2006 | 01:04 PM
DieL's Avatar
DieL
Default Rear end goes every direction under Accel/deccel !!!
Sorry the other post didnt post up and i lost my page long essay somehow
Oh well to make it short. I think the alignment is way off and may be the reason for this. Under accel i have to correct the steering because its all over the road. No it isn't the power Im talking 15-20% throttle only (not tuned good yet). It isn't tires/wheels because it did this with my winter rims and with my new rims/tires same thing. I had it alignmed 2 weeks ago but they did a terrible job. Im going again tommorow morning for a proper alignment at a reputable shoppe so I'll know how off the settings were.
My question to you guys is what should I look for to be loose under the car in the back?
Car has all new rear dana 44 with 3.73s ( possible install issue?)
All new bushings throughout. VBP Camber and Toe rod kit. has beam plates too.
Any suggestions?
Old Jul 6, 2006 | 02:48 PM
mk842766's Avatar
mk842766
I had a similar problem, turned out to be a broken bolt on one of the "dogbones"....was an easy fix, but it sure wanted to "swap ends" until I replaced the bolt....
Old Jul 6, 2006 | 04:45 PM
bogus's Avatar
bogus
you did bushings? Have you driven it since?
I read here in another thread that you have to preload the poly's, or they will bind... I am wondering if you are encountering this problem, or one like it.
Old Jul 6, 2006 | 04:49 PM
RichS's Avatar
RichS
I had simular issues with bad half shaft u-joints. The car was all over the place giving it just a little gas.
Old Jul 6, 2006 | 04:58 PM
L71Maynard's Avatar
L71Maynard
This was my problem as well. Both my rear bearings were bad and one of them was actually broken in 2 pieces.
Dave
Old Jul 7, 2006 | 09:32 AM
C4DC's Avatar
C4DC
St. Jude Donor '06
I'd start by checking the wheel bearings.
Old Jul 7, 2006 | 10:05 AM
DieL's Avatar
DieL
Wheel bearings are brand new GM units. about 30 minutes driving on them. No play whatsoever. u-joints are new as well as the halfshafts incl driveshafts as well. all bushings in the rear are new too.
I went to a very knowledgeable alignment shoppe this morning and after he set it up.. it was still there. We checked all the suspension mounting locations and noticed rubbing marks near the Diff carrier bolts on each side. Looks like the entire assembly is moving side to side. This is happening even over grooved or uneven pavement. He said the sleeves for the bolts or the wrong size bolts may have been used to tighten up the diff.
Going to try and get it checked out asap. I'll post the results ! there goes my weekend
Old Jul 7, 2006 | 10:57 AM
Blownfuel1's Avatar
Blownfuel1
I had a very similar problem in my C-3, but it wasn't too hard to Diagnose, I had just been involved in an accident, and the front cross member was halfway torn out of the frame! Couldn't see it from above, but after putting it on a lift, it was really obvious! Apparently C-3's are pretty notorious for cracked front crossmembers, but don't know of it being a problem on C-4's. Probably not what's wrong with your car, but it is one more thing to check and eliminate.
Old Jul 7, 2006 | 01:09 PM
bogus's Avatar
bogus
Originally Posted by Blownfuel1
I had a very similar problem in my C-3, but it wasn't too hard to Diagnose, I had just been involved in an accident, and the front cross member was halfway torn out of the frame! Couldn't see it from above, but after putting it on a lift, it was really obvious! Apparently C-3's are pretty notorious for craked front crossmembers, but don't know of it being a problem on C-4's. Probably not what's wrong with your car, but it is one more thing to check and eliminate.
that's a good thing to check, but doubtful.
the steel they used to make the frame rails on these cars is some of the hardest **** I have ever tried to drill a screw into... damn...
Old Jul 7, 2006 | 06:07 PM
jburnett's Avatar
jburnett
I skimmed through most of the posts and didn't see this mentioned but it is a major cause of the rearend stepping out: the torque arm... Make sure the c-beam is torqued properly because if it's not it WILL make the car squirrely...
-Jeb
Old Jul 7, 2006 | 06:18 PM
DieL's Avatar
DieL
Thanks for the replies so far guys. I spoke to the shoppe who did the diff/rear end install and they said the bushings were press fit into the carrier and they had sleeves in them. They basically ruled out that as a possibility. I think by looking at the bolts if the carrier was moving on them you would see the marks by the nut or bolt.
I left a message for Bill at ZFdoc who did my tranny and asked him the possibility of the c beam being loose causing this. I do have new beam plates on it but My guess is that they are loose. I hope this isn't causing excessive loads on the trans. I also noticed that the tranny although brand new and rebuilt , whines alot when coasting to a stop, even in neutral. Sounds to me like some part of the driveline is not straight and may be cuasing this, relating the 2 areas of concern.
I'm going to take a look underneath and see what i can feel and tighten. that's all i can do until i get a shoppe to give me time to bring it in to take it apart.
Old Jul 7, 2006 | 06:20 PM
DieL's Avatar
DieL
-Jeb
jeb that's exactly how it feels. Sometimes its straight and only at higher speeds its worse. On/off the throttle brings the quirrely feeling at will, other times it sort of follows unevern pavement. I think that it's definitely the C-beam bolts.
Old Jul 7, 2006 | 06:26 PM
AKS Racing's Avatar
AKS Racing
-Jeb
A tale tell sign of this is that the shifter moves up and down when accellerating/decellearting. I know this because....
Old Jul 7, 2006 | 06:32 PM
DieL's Avatar
DieL
I'm fairly sure my shifter isn't moving much :/ What is involved in tightening all the bolts on the beam top and bottom? Exhaust.. driveshaft ?? trans and diff need to be dropped?? I'm too tired to look under it right now.. I'll save it for later tonight and see what i can tighten under there
Old Jul 7, 2006 | 07:16 PM
AKS Racing's Avatar
AKS Racing
Typically, the cat-back portion of the exhaust will need to be dropped. Tightening the c-beam bolts (2 in front/trans, 2 on the back/diff) is relatively straightforward (especially if you have beam plates).
Aaron
Old Jul 7, 2006 | 07:19 PM
DieL's Avatar
DieL
yeah the beam plates are there. So it's accesible with just exhaust removal ? top and bottom ?
Old Jul 7, 2006 | 08:10 PM
AKS Racing's Avatar
AKS Racing
You do not need access to the top if you are running beam plates. The beam plates capture the top nuts so that you only have to turn the lower bolt heads.
Aaron
To Rear end goes every direction under Accel/deccel !!!
Old Jul 7, 2006 | 08:14 PM
steve40th's Avatar
steve40th
St. Jude Donor '03 & '05
Did you torque the rearend suspension pieces with the Vette up in the air, and not in a pre loaded state. Supposedly that (up and not loaded)will cause the cars suspension pieces not to be torqued correclty, and can cause the suspension be a little out of whack.
Old Jul 7, 2006 | 08:38 PM
DieL's Avatar
DieL
pretty sure it was tightened up on the hoist.
Old Jul 7, 2006 | 08:57 PM
steve40th's Avatar
steve40th
Was this a drive on rack or one where the tires are a hanging?
