Where is the ccm located
Old Jul 6, 2006 | 01:36 PM
rrhayden's Avatar
rrhayden
Default Where is the ccm located
I have a 92 lt1 and am getting some strange codes and want to clean the electrical connections on the CCM. Can anyone tell me where it is located?
Old Jul 6, 2006 | 01:44 PM
bogus's Avatar
bogus
what kinda codes are you getting?
The CCM is below the radio, well, in that general area.
You really need a Helm Factory Service Manual when you start getting into problems of this nature.
Old Jul 6, 2006 | 02:28 PM
rrhayden's Avatar
rrhayden
Hey Bogus,
I know I need to get one. Im an old fart and keep saying its not fun to work on cars anymore, but I just cant seem to help myself. I get an intermitant service ASR light, the display showes a code 41 in CCM diagnostics. Which is loss of communication ECM, so my thought is a dirty connection or ground.
Old Jul 6, 2006 | 02:37 PM
VR'92's Avatar
VR'92
From: I'm the walkin dude I can see all of the world...
St. Jude Donor '03
Originally Posted by rrhayden
Hey Bogus,
I'm currently going through this right now with my 92. Same code 41 etc.
Save yourself some trouble and clean the grounds for the CCM and ECM first before digging into the dash. The CCM is not easy to get out.
The grounds for both is located right above the oil filter and next to the digital oil temp sending unit on the side of the block. There is a large bolt that holds a negitive battery cable and 3 large internal computer grounding wires in place here.
Mine was extremly dirty and is definitly the cause of my problems. After cleaning it things have gotton much better but I'm still getting some slight intermittent problems. I think these are actually coming from the wired connectors themselves as they are also very dirty. This is definitly the source of my problems though.
bogus's Avatar
bogus
are you getting codes elsewhere?
Any ECM codes? Any EBCM codes? If the CCM is throwing the C41, it would lead me to believe that the EBCM (ABS/ASR) is failing to send info or poll upon request, versus, the CCM causing it. If the CCM causes the code, I don't think it would throw a code on itself, it would manifest in the module that was trying to talk to it. Follow?
I would pop the lid on the drivers side storage bin (EBCM) and check there, first... it will be helluva lot easier.
Old Jul 6, 2006 | 02:41 PM
VR'92's Avatar
VR'92
St. Jude Donor '03
Trust me. Its the ground. http://forums.corvetteforum.com/show....php?t=1218103
Old Jul 6, 2006 | 02:50 PM
rrhayden's Avatar
rrhayden
VR-92
Thanks I think you are on the right track. The whole saga started a few months ago with an intermitant failier to start. Turn the key she fired right up then in about 1 to 2 seconds she would stop. If you pushed the key to the crank position no restart. Then I determined that if you turned the key off and restarted she ran fine. Once started no indication of an issue. The I noticed that every time the no start happened the service asr light was on. SO now if you turn the key to on and wait for the bulb test to finish, if no asr light is on she starts fine, if it is on trun the key off and try again.
Old Jul 6, 2006 | 02:51 PM
rrhayden's Avatar
rrhayden
Bogus,
No there are no codes in the ecm or the bcm only showes and modual 1 (ccm) code 41
Old Jul 6, 2006 | 03:11 PM
bogus's Avatar
bogus
you are getting a flickering ASR light? Is the ABS light coming on, too?
I would think the problem is in the EBCM...
Old Jul 6, 2006 | 03:36 PM
rrhayden's Avatar
rrhayden
Bogus,
I know this whole thing ir strange. No abs light at all and no codes from the abs controller. Just ranndom ASR light.
Old Jul 6, 2006 | 11:07 PM
rrhayden's Avatar
rrhayden
Old Apr 16, 2024 | 05:56 AM
Lindyp38's Avatar
Lindyp38
Cruising
Default G106 ground point
How did you get to that ground ? It looks pretty tight. Did you remove the battery? Thanks In advance
Old Apr 17, 2024 | 12:16 AM
CA-Legal-Vette's Avatar
CA-Legal-Vette
Approaching the record for a zombie thread. Almost 18 years. Well done!
To Where is the ccm located
