Engine Fan not Working
Old Jul 6, 2006 | 02:40 PM
JasenZ51's Avatar
JasenZ51
Default Engine Fan not Working
I have a 85 Z51 and the fan on the front of the rad is working fine, but the fan that is in betweent he engine and the rad does not seem to be working...IS there any tests I can do to check this fan? If it turns out to be defective what are my options???
Thanks!
Old Jul 6, 2006 | 03:21 PM
jfb's Avatar
jfb
Sure, unplug the fan and jump 12v to the fan motor and see if it runs. Eventually the brushes wear out and the fan motor quits. Also, the fan relay can fail and with the ign in run, jump the green/white wire on the fan relay to ground. The fan should run and you should hear the fan relay click. If not, replace the fan relay after you have measured 12v going to the fan relay with ign in run as there is a fusible link on the 12v line.
Old Jul 7, 2006 | 03:48 PM
JasenZ51's Avatar
JasenZ51
Where is the Relay located on my 85?
Old Jul 7, 2006 | 03:55 PM
jan-erik's Avatar
jan-erik
Hi
It is located on the left wheel well lust under the (in front of ) the brake booster or main brake pump
Old Jul 7, 2006 | 07:22 PM
DieL's Avatar
DieL
location of this relay on a 93 ? sorry to bud in.. I'm having the same problem !
Old Jul 10, 2006 | 08:27 PM
JasenZ51's Avatar
JasenZ51
Originally Posted by jan-erik
Hi
Yup, thats where it is, thanks!
To Engine Fan not Working
