low coolant indicator - but not so ???
Old Jul 6, 2006 | 04:48 PM
jshyman's Avatar
jshyman
Default low coolant indicator - but not so ???
Most times I start the car in the AM the indicator for low coolant level comes on. After I drive a block or so it goes off. I believe the sensor is it the "high fill tank".
Today, I actually looked in the tank and it was basically empty. The overflow tank was beyond full. My guess is the the coolant is sucked back in the system as the engine warms. Although this is not a big problem, I can hardly believe it was intended to function in this fashion. I would genuinely appreciate any insight you might have............... thanks.
Old Jul 6, 2006 | 04:57 PM
STL94LT1's Avatar
STL94LT1
There should always be coolant in the surge tank/high fill.
Old Jul 6, 2006 | 05:08 PM
Square's Avatar
Square
What year is your car?
Old Jul 6, 2006 | 07:18 PM
jshyman's Avatar
jshyman
The car is a 91. I should mention that when running, it never has an overheating problem.
Old Jul 6, 2006 | 07:21 PM
jimmers's Avatar
jimmers
When the car is cold it should be at the cold level indicator in the overflow.
Old Jul 6, 2006 | 07:33 PM
jshyman's Avatar
jshyman
When the car is cold, it is way beyond the full level. When the car is warm it is correct ???????
Old Jul 6, 2006 | 07:51 PM
ultraviolet70's Avatar
ultraviolet70
If the overflow tank is overfull and the surge tank you have one of two problems you either have a fairly large leak high in system (because as coolant drops in temp it contracts therefore pulling vacum and suckingthe coolant back into the surge tank that it expelled when it got hot and expanded), but since you not metioning a leak I'd assume your probably gonna get off real cheap and all you really need is a new cap for the surge tank.
Old Jul 6, 2006 | 07:56 PM
jshyman's Avatar
jshyman
Actually, The surge tank cap is relatively new. Perhaps I got the wrong pressure rated cap ????
Old Jul 6, 2006 | 11:05 PM
ultraviolet70
Actually rating shouldn't affect the coolant recovery process, the rating is related to the pressure requried to lift he cap of it's seat and force coolant into the overflow i.e. 16lbs. I think??? it only takes an inch or two of vaccum to open the valve in the center of the cap to pull the coolant from the overflow back into the system. I wonder if you possibly got a faulty cap, or have you been in the cooling system recently and just didn't get it fully purged/filled? Because if you don't start out with a full system, the system will not fill itself especially when you consider the drastic difference in height between the surge and overflow.
Old Jul 6, 2006 | 11:31 PM
jimmers's Avatar
jimmers
My 90 is 17lbs (117 kpa).
To low coolant indicator - but not so ???
