Help!!!! 92 Vette Problems Help!!!! 92 Corvette Problems
Old Jul 7, 2006 | 07:29 AM
Damian666's Avatar
Damian666
1st Gear
Default Help!!!! 92 Vette Problems Help!!!! 92 Corvette Problems
I have a 1992 Corvette with problems.
> I was driving and heard a high pitched whining sound coming from the ASR
> ABS compartment and the service ASR service ABS lights were on, It was not
> the ASR/ABS motor. I turned the vehicle off took the key out and the sound
> would not go away. I let the car sit several hours the sound finally went
> away, started the car up service ASR and service ABS lights were out. The
> next day under acceleration service ASR/ABS lights came on and
> simultaneously the security warning light flashed and when I shut the car
> off it would not start again. I can get the car to start after trying to
> start and pulling the key out and trying to start again 50 to 100 times,
> car will only start when service ASR light is off. Once car is started
> runs normally until you try to accelerate as soon as ASR service light
> comes on, security system warning flashes, once you shut car off it won't
> start again. I have had problems with the ASR/ABS light flashing since I
> have owned the car the last 6 years and it s
> eems to have weak rear brake bias. I don't understand why the ASR should
> be linked to the security system, if infact it is. I never leave the car
> unattended, what is the procedure to bypass security system? Have any
> ideas???????? Thanks Bill
> p.s.
> This concerns me because I also have a 94 convertible with the same
> system, and am afraid it will rear its ugly head in this vehicle also.
Old Jul 7, 2006 | 08:39 AM
KDuniverse's Avatar
KDuniverse
check the codes
