Rough idle ?
Old Jul 7, 2006 | 08:12 AM
Randy93's Avatar
Randy93
St. Jude Donor '06
Default Rough idle ?
I was reading my Helms manual last night(I have got to get a life) and came accross this, The Park/Neutral switch can effect idle.\
How can it cause idle problems?
The reason I ask, is my idle problems started about 3-4 days after my tranny was rebuilt.
Also, where is it on the tranny so I can do a visual check?
Old Jul 7, 2006 | 08:52 AM
Vetracr's Avatar
Vetracr
Park / neutral switch has no effect on idle. It only allows starter circuit to be engaged. Its a safety only item. Look elsewhere for an idle problem. More description of the problem would help.
Larry
Old Jul 7, 2006 | 09:19 AM
Randy93's Avatar
Randy93
St. Jude Donor '06
It runs rich, the only code I get is for the EGR and that started about 2 weeks after the car started running rich, so I think that was caused by the rich condition. The car had a slight miss when my tranny went out, but ran good. Then about 3-4 days it started running very rough when the car got warm and performance was terrible. I think the computer compensated for some of it, because it runns alot better. But it also runs rough all the time now, I replaced the IAC because I broke it when I was cleaing it. The injecters all OHM about 1-2 OHM's from one another, I had just replaced the plugs and wires about 6 mths before. So I am searching for anything to help, the Helms manual says the switch helps control the EGR which would effect the idle.
Is this not true?
Again, thanks!
To Rough idle ?
