Stalling '85
Old Jul 31, 2006 | 09:47 AM
Yototimeage's Avatar
Yototimeage
Ignition module if it cranks and does not fire
Old Jul 31, 2006 | 04:36 PM
hurricanejames's Avatar
hurricanejames
I believe you hit on the answer yourself...Check your battery. These cars take an enormous amount of spark to run properly. If your battery is compromised somehow, your car will exhibit the problems you've described. Check your battery terminals, if they're loose or corroded, your car will not idle, stumble under acceleration, and generally sound like it's running of 5 cylinders. How do I know? Happened to me. Now, is this always the case? No, but it's a distinct possibility and an easy place to start. In any case, good luck.
Old Jul 31, 2006 | 06:02 PM
zoro's Avatar
zoro
Originally Posted by zoro
The car has been running fine for about a week.
Old Jul 31, 2006 | 09:19 PM
j3studio's Avatar
j3studio
Cruise-In V Veteran
St. Jude Donor '06
Ask the mods to lock the thread - all this further discussion can only make it worse...
Old Aug 1, 2006 | 08:06 AM
hurricanejames
yeah...all this trying to help somebody is really tedious.
