Replacing u-joints
Old Sep 1, 2001 | 07:09 PM
nsimmons's Avatar
nsimmons
Default Replacing u-joints
so im finaly gonna bite the bullet and do my ujoints..i picked them up today and a small peice of pipe..my plan is to use my vise, a socket and the pipe to push them out of the shafts. like it shows in the haynes manual.Sound ok? Any advice would be good
Old Sep 1, 2001 | 07:35 PM
Mrcorvette91's Avatar
Mrcorvette91
Default Re: Replacing u-joints (nsimmons)
If you take your time, and work carefully, there is no problem. I changed all four of mine out (I assume you are talkiing about the drive axles) this spring. I dreaded it for a looong time, but after I got started, it wasn;t too bad. Close and tight places to work, but if you follow the Haynes manual, you will do fine. It took me about 4 hours on the first side, and about two on the second side..*S* You learn from the first one...Good Luck!!! :chevy
Old Sep 2, 2001 | 03:01 AM
CORKVETTE1's Avatar
CORKVETTE1
Cruise-In IV Veteran
Cruise-In V Veteran
Default Re: Replacing u-joints (Mrcorvette91)
a lot easier if you use some heat also :cool:
Old Sep 2, 2001 | 03:24 AM
weekendwrench's Avatar
weekendwrench
Put the new u joints in the freezer before you start your work. Use a propane torch to heat up the loops on the end of the drive shafts. The heat will make it easier to get the u joints out and the cold new joints will shrink a little making them easier to get in.
Old Sep 2, 2001 | 06:53 AM
nsimmons's Avatar
nsimmons
Default Re: Replacing u-joints (weekendwrench)
i got one side done after about 4 hours..the pain was getting the half shaft out, no one told me i had to unbolt half the rear suspension..i guess i should of read the shop manual first . The book says to disconnect the leaf spring, the tie rod and the bar that adjusts camber(cant remember the name) i didnt feel like unbolting everything so i just un did the camber beam, and pulled down on it really hard and the shaft dropped out..the ujoints slide right out and the new ones slide right in, no problems. Then i fought with it for 2 hours trying to get the shaft back it..i finally realized if you start pumpkin side first and slide it up over the diff, you'll get clearence to get the shaft in. I just have to torque down the shaft bolts and reconnect the camber beam, which looks like it'll be fun, i have to pull it back a good 3 inches and push it up 2..i think i'll get some re-enforcements..
Old Sep 2, 2001 | 08:10 AM
NoWorries's Avatar
NoWorries
Wow, I changed one on my drive-shaft(the other was fine, I'm just an idiot and lost bearings thats why I had to change the one) and it was a major pita.
And thats with a 50 ton press(only used about .32 of those tons) and all of the right equipment.
Good luck with the other side and drive-shaft. To save a mess...I think when you pull the drive-shaft the transmission will drain.
Old Sep 2, 2001 | 10:42 AM
CORKVETTE1's Avatar
CORKVETTE1
Cruise-In V Veteran
Default Re: Replacing u-joints (NoWorries)
yea those half shafts are a pain i would change both if you are allready unde their even if the other is ok it cant be to far behind :cool:
Old Sep 2, 2001 | 11:37 AM
BobMachus's Avatar
BobMachus
Default Re: Replacing u-joints (CORKVETTE1)
I was driving down the freeway the other day when the right rear started making an odd, rhythmic swishing noise. I got off on an exit and nothing. As I accelerated away from the light it make the swishing noise again, but only for about 3 seconds then stopped. Well about a mile later as I pulled away from another light I REALLY heard it. Now the noise doesn't stop and it is more of a metallic grinding/squealing. I turn off the car and get it towed home and jack it up. It was one of the u-joints on the passenger side. I had a new one in and was driving in 2 hours following the directions in the Haynes. No heat, no freezer. When I pulled the cap from the bad pinion all that came out was black dust and little tiny bent and shiny pieces of needle bearing. Yikes! I replaced the other side a few days later just to be safe.
Old Sep 2, 2001 | 12:04 PM
mackeyred96's Avatar
mackeyred96
From: Former NCM Drag Racing coordinator, National director Corvette Challenge Spring Hill, Tennessee: Whiting, New Jersey
Cruise-In VI Veteran
Cruise-In VII Veteran
With the shafts out I think it easer to take the to a shop and have then install. The little bit they charge is well worth it.
Old Sep 2, 2001 | 01:00 PM
J Z06's Avatar
J Z06
Default Re: Replacing u-joints (mackeyred96)
Cork:
85 CORVETTE
BEST ET:11:57 AT 117.37UNCORKED
11:70 AT 116.24 THROUGH THE PIPES
340RWHP-420RWTQ
BOTH TIMES ON M&H STREET TIRES
What size motor? This is haulin' the freight!
Old Sep 2, 2001 | 01:41 PM
CORKVETTE1's Avatar
CORKVETTE1
Cruise-In V Veteran
Default Re: Replacing u-joints (JD 90 383)
it is a 406 right now kicking around the idea for a larger one for next year thou here is a link to the car and all the modifications the same modifications and a 350 went mid 12s all day long http://hometown.aol.com/aheis46312/myhomepage/auto.html
hopeing for 10s next year :cool:
Old Sep 2, 2001 | 10:24 PM
nsimmons's Avatar
nsimmons
Well for those following..i just finished both the half shafts..it still clunks a bit when i change gear, but i know this is the rear joint on the driveshaft. at low speeds there is zero noise..no clunking ticking, anything, a big improvment. I havent done the drive shaft joints since i dont have the ujoints for it..I'll do them next weekend
[Modified by nsimmons, 6:25 PM 9/2/2001]
Old Sep 3, 2001 | 01:02 AM
YLO Z06's Avatar
YLO Z06
2023 C5 of the Year Finalist - Modified
Mackey, most shops around here either won't do them at all or want like $500 just to press the u-joints out and in, not even remove the half-shafts from the car
:eek: :crazy: ! So, like others, I'm doing my own u-joint repairs (this week, actually).
Old Sep 4, 2001 | 02:53 PM
jcazin's Avatar
jcazin
Default Re: Replacing u-joints (94vette)
ya, I noticed that with mine- the shop wants the entire job, and they'll bend you over if you just want the u-joints pressed.
Old Sep 4, 2001 | 02:55 PM
BobMachus's Avatar
BobMachus
Default Re: Replacing u-joints (jcazin)
I have never had any trouble just using my 6' bench vise and sockets. I guess I an just lucky, but I have done probably 30 u-joints on my and others cars so far with no trouble.
Bob
To Replacing u-joints
