concerned?
Old Jul 9, 2006 | 05:29 PM
printer1's Avatar
printer1
St. Jude Donor '06
Default concerned?
i just came from a long road trip--140 miles..had on crusie most of the way at 70..
on the way back my SERVICE ENGINE LIGHT came on
my fuel pressure was 40
fuel temp 211
coolant around 200
i just has car in shop for tuneup last week and he said to call should the idiot light come on
do you think 2 much driving in the heat or are these avg temps
thanks
Old Jul 9, 2006 | 05:35 PM
RRT vette's Avatar
RRT vette
Pull the code. http://www.troublecodes.net/GM/
Once you get the number...post it here. Those numbers are not specific for a vette.
Old Jul 9, 2006 | 05:37 PM
mseven's Avatar
mseven
fuel temp 211coolant around 200
thanks
Fuel temp.??
I'm guessing it threw a code?
Old Jul 9, 2006 | 05:41 PM
printer1's Avatar
printer1
St. Jude Donor '06
Default when i turned the car off
after pulling over and turning car off- the service engine light went out...that pulling up a code looks real complicated to a newbie--let me take it for a spin and see what i get i'll post back
thanks
Old Jul 9, 2006 | 05:42 PM
RRT vette's Avatar
RRT vette
Originally Posted by mseven
Fuel temp.??
I completely miss that one.
Turn ignition switch to OFF position
Locate Data Link Connector (DLC),
Jumper the A&B terminals(a paper clip or a jumper wire work ok) in the shape of a U
Turn Ignition switch to ON position.
Count the flashes on the "CHECK ENGINE" or "SERVICE ENGINE" light.
FLASH, pause, FLASH, FLASH = code 12
Old Jul 9, 2006 | 05:55 PM
CFI-EFI's Avatar
CFI-EFI
That must be a '96. Those darn OBD IIs will measure EVERYTHING including your PERSONAL gas pressure. That might be pretty warm for fuel, I've never checked mine. I didn't realize the later cars had a fuel pressure gauge, either. The water temp looks great. Pull the codes and follow the trouble shooting charts in your FSM, otherwise you are going to end up throwing money at it, needlessly.
RACE ON!!!
Old Jul 9, 2006 | 06:06 PM
Corvette Kid's Avatar
Corvette Kid
Large Impressive Member
From: Good health is merely the slowest possible rate at which one can die
St. Jude Donor '04-'05-'06-'07
Was the light on at anytime recently prior to the tune-up? The reason I ask is because I find it odd that the tech would have said to call if the light comes on. It makes me wonder if he may have damaged a connector or something else while working on it (easy to do when plastic get old and brittle) and patched it up hoping for the best. I had quite a few that had been boogered up but lucked onto a low-mileage harness, which allowed me to make some good repairs while doing the engine change recently.
Old Jul 9, 2006 | 06:15 PM
printer1's Avatar
printer1
St. Jude Donor '06
Default update
just took her for a short ride cruised at 60mpg--no warning lights
temp-188 max
pres-67 max
coolant-1995 max
Old Jul 9, 2006 | 07:25 PM
MikeC4's Avatar
MikeC4
temp-188 max
pres-67 max
coolant-1995 max
60mpg ! coolant-1995 F.....Your killin' me!!!
Old Jul 9, 2006 | 07:29 PM
mikey whipreck's Avatar
mikey whipreck
some auto stores - such as Autozone - will pull your codes for free if you're still concerned, and you aren't able to.
Old Jul 9, 2006 | 07:52 PM
printer1's Avatar
printer1
St. Jude Donor '06
Default light never came on before
Old Jul 9, 2006 | 07:54 PM
printer1's Avatar
printer1
St. Jude Donor '06
Default main question
are these numbers in the normal range for an 88 vette:
just took her for a short ride cruised at 60mph--no warning lights
oil temp-188 max
oil pres-67 max
coolant-199 max
Old Jul 9, 2006 | 07:57 PM
RRT vette's Avatar
RRT vette
The numbers look fine. This is probably an intermittant code and will be hard to pull unless you are using a scanner when it shows.
Old Jul 9, 2006 | 08:01 PM
printer1's Avatar
printer1
St. Jude Donor '06
Default thank you
thank you
Old Jul 9, 2006 | 08:22 PM
rick lambert's Avatar
rick lambert
I think the majority of us were a little nervous when we first pulled codes. It's really no big deal, and you need to check and see if a code was thrown.
To concerned?
