Rough running
Old Jul 9, 2006 | 06:00 PM
hman1987's Avatar
hman1987
Default Rough running
This car is driving me insane. After replacing two of the O2 sensors, first with Bosche then again with AC Delco the SES light returned. I figured it had to be a wiring issue so I checked the wires and everything "looked" fine. I noticed the negative battery cable was a little loose at the battery so I tightened it.
The SES light is gone now but the car is running rough starting about 20-30 seconds after start up. I also noticed that the lights on the dash would dim or brighten when I pressed the gas. She runs fine down the street but I can smell that she is still running rich when I pull her in the garage.
Old Jul 9, 2006 | 06:04 PM
RRT vette's Avatar
RRT vette
Do you know that the injectors are good and not leaking?
Old Jul 9, 2006 | 06:09 PM
hman1987's Avatar
hman1987
I really don't know. How would I check? The codes that were stored on the SES when I had the O2 problem were all related to no activity from Bank 2 sensor 1. Now that the SES light is off I don't know. At idle you feel it run really rough but down the street it seems ok.
Old Jul 9, 2006 | 06:24 PM
RRT vette's Avatar
RRT vette
You can pull the plugs and look for gas...would point to a leaky injector. You can get a fuel pressure guage and see how fast the fuel pressure drops after the engine is shut off. You can also ohm the injector coils hot and cold to see there resistance. Is the only code you get for the O2 sensors? What is the code rich or lean.
Old Jul 9, 2006 | 06:50 PM
hman1987's Avatar
hman1987
The codes that were present were:
P0151- O2 Bank 2 Position 1 weak signal
P0154- O2 Bank 2 Position 1 Insufficient Activity
P0300- Random System Misfire
P0174- Bank 2 Lean Condition
The SES light is back on at this point. I don't have a scan tool, I will have to take it get the codes read again.
Old Jul 9, 2006 | 07:16 PM
MikeC4's Avatar
MikeC4
Try swapping the Bank2 O2 with Bank1, clear your stored error codes, and see if your error moves to Bank1. If yes, you got a "bad" new sensor. This is not unheard of.....unfortunately.
BTW, you can get your error codes quite easily without a scan tool. Just follow the directions detailed here, and goto the link pertaining to your '87 vin#:
http://www.troublecodes.net/GM/
***********EDIT***************
and the 'P0174- Bank 2 Lean Condition' will make your PCM "Richen up" your Bank2. How does you engine run when cold??? Is your rich problem only noticable when the engine has warmed up?
Old Jul 9, 2006 | 10:26 PM
hman1987's Avatar
hman1987
I thought the problem was a bad replacement O2 but this is the second one I put in there. The first one was a Bosche and when that did not solve the problem I went to the dealership and got an AC Delco O2 sensor....problem returned.
My baby is a 96 with OBD II so I can't do the PIN out and flash codes. When the problem first started the she would run fine when she was cold from sitting up over night. The SES would even go off for awhile. But now the light stays on all the time unless the codes are cleared. Now when I start her, she runs good for about the first 20-30 seconds and then starts running rough at idle.
Old Jul 10, 2006 | 01:36 PM
hman1987's Avatar
hman1987
I also think I may have a problem with the alternator as the I mentioned in the orignal post. The lights on the digital dash seem to get slightly brighter when I step on the gas at idol. This has me thinking as the shop told me that the O2 sensor seem to funtion (switch as it is supposed to) when the RPM's are above 2500.
Old Jul 10, 2006 | 02:07 PM
pr1mu5's Avatar
pr1mu5
Default hmm.
I know this isn't going to help, but I just got rid of my 96 Yukon (5.7L) because I was running down all these same codes. (o2 sensor codes, and then the dreaded P0300 code that I was never able to resolve fully). Fixed it by replacing cats, all O2 sensors, camshaft position sensor, injectors cleaned, tune up, and then the head gasket blew on me.
I just hope you're not going where I was headed in the Yukon. Same exact codes though, just brought back (bad) memories, and had to comment.
Good luck!
Old Jul 10, 2006 | 03:47 PM
Randy93's Avatar
Randy93
St. Jude Donor '06
Ok, the O2's only start woking after the car reaches a certain temp, if it starts happening 20-30 sec. after startup, it is not the O2. The code you are recieving is an effect, not the cause. You need to look farther, mine was a combination injectors, stuck IAC and vaccuum leak.
Get an OHM meter and check your injectors, clean your throttle body and IAC, do not drop the IAC as I did and check for vac. leaks.
Old Jul 12, 2006 | 10:45 PM
90BlackC4's Avatar
90BlackC4
2nd Gear
Randy93 is correct...if you receive the code within 20 to 30 seconds after start up it would be because of un-spent fuel vapores...this is caused mostly by stuck or leaky fuel injectors. Test them first and you will most likely find one on bank 2 side.
Old Jul 13, 2006 | 12:00 AM
Fasterer's Avatar
Fasterer
Is the exhaust system tight, Any air leak seen by o2 sensors would be seen as lean condition and cause system to dump extra fuel.
To Rough running
