Performance Trouble with new Vette
It was running like a dream, and I don't recall doing anything extremely stupid, just driving it like it should be, and now there is a lower exhaust note, as if something is 'choking' my exhaust, and there is some vibration coming from the engine. No codes/dummy lights. If I push in the clutch, there is no change in vibration, so that's not a problem. I notice if I turn on the A/C, the vibration gets worse. If I am cruising, the vibration/exhaust choking is not noticeable, but if I step on it it sounds like a motorboat.
I know I had a small exhaust leak pre-cat, could it just be that, maybe it got bigger? Could that cause the vibration though?
Obviously I need to take it in to a mechanic, just wondering if you can offer some advice on where to start looking...
Is this something I should start to seriously consider with my vette? I plan on 'driving it like I stole it' and frequenting the race track with it, so am I in for a world of hurt at the mechanics if I don't start learning to rebuild this stuff myself?
For instance, my F-150 was running rough and cutting out while driving. I knew there could be several things that I knew of that could be causing it and I figured there were probably a few more that I didn't know about. The mechanic found that the problem was a leaking intake gasket that was dripping down into one of the spark plug pits. It would have taken me forever to find this as it couldn't be seen without quite a bit of disassembly. They wanted 3 or $400 to fix it. I took it home and spent $50 on the gasket and $30 or so for antifreeze, oil, and plugs. Sure, it took a few hours of my time. There was some swearing and beer consumption. But it wasn't that difficult and was a heck of a lot cheaper. Really the only way to get confident about this kind of stuff is just start doing it. If you get stuck, make a few phone calls or come on here and describe your problem. Get a Haynes or Helms book to help guide you and you'll be set. Ultimately you have to make the decision whether you want to pay someone else to do the job or tackle it yourself. I prefer to tackle most jobs myself.
When I did my first clutch replacement, I needed a lot of support from my brother to get me through it. Since then, I've done several engine swaps, several clutches, many brake jobs, leaf springs, starters, intake gaskets, carburetors, timing chains and belts, water pumps, radiators, motor mounts, traction bars, swapped a rearend, u-joints, interiors, steering boxes, shocks, transmissions, etc. and even built my own motor from the bare block up, all with a 100% success rate. You already have the tools, all you need is the knowledge and there is only one way to get that. Just do it. I've saved thousands of dollars over the years.
And I have an OBDII scanner, but my 94 lacks the port to plug it into.
Is it worth trying to read the codes, if the SES light isn't on? Could there be anything in there to be read?
yes, you could have History error codes stored, and the SES light does not have to be on.
Easy to pull yourself:
http://www.troublecodes.net/GM/
Well sunuva... there is no 'B' terminal to jump the 'A' to. That link says I need a scanner then? It looks like my OBDII scanner will fit, should I try it? Any other way I can pull the codes myself?
I think I'll bring it to a local guy who is a corvette specialist, let him diagnose the problem, and if it's expensive I think i'll start to teach myself how to do engine rebuilds...
But the bad news is the sound is definitely coming from the passenger side of the engine, sounds like a 'woop woop woop woop' almost like a bunch of bullfrogs. Too bad my mechanics are busy for two weeks, guess I'll drive my beater car for a while until I can figure it out.
82,000 miles, and I have no idea when the last tune up was done. Guess I may as well change the sparkplugs for the hell of it, or at least pull one and see what the condition is...
Bullfrogs in the motor is new to me and I can not find a diagnostic procedure for that in my FSM. About the only thing I can thing off for that would be a loose spark plug letting compression get past it, or the exhaust leak. Possible right side cat breaking up inside and causing exhaust restriction? Just a few simple/easy things to check. Good luck with it.
PS--I was thinking you had a 95 with true dual exhaust. If the 94 has the precats, y pipe and then main cat I would bet $$$ to donuts the precat has come apart inside and pieces are getting pushed back into the main cat, causing the exhaust note change. Not so sure about if that would cause a vibration though, but possilbe I suppose.
