courtesy lights when wet
Old Jul 11, 2006 | 03:27 PM
lakerat's Avatar
lakerat
Default courtesy lights when wet
90 vert - Today, is a very rare day that I took the car knowing that it was going to rain. However, after getting in to head out for lunch, the courtesy lights stayed on. This happened before after a wash.
So, I suspect something shorting out when wet. Any ideas where to look? I replaced the driver's side switch twice in the past two months thinking that was the problem. (Delco is my enemy....)
Old Jul 11, 2006 | 03:42 PM
CentralCoaster's Avatar
CentralCoaster
From: San Diego , CA Double Yellow DirtBags 1985..Z51..6-speed
I presume your headlight **** isn't twisted to the left?
Does the alarm system work? If not, it's probably a bad door plunger switch. These should disconnect the courtesy light ground circuit when the door is shut.
Old Jul 11, 2006 | 03:53 PM
lakerat's Avatar
lakerat
since I've replaced the plunger switch twice recently, I'm thinking it may be in the wiring somewhere.
Old Jul 12, 2006 | 01:04 AM
Insane1's Avatar
Insane1
Had the same thing happen on my car after a heavy downpour. Car dried out in a few days. Never could find the culprit.
Hey CentralCoaster, is that a picture of you and your vette on racelegal.com website with the fastest reaction time?
On a 90 the headlight **** does not control the dome lights. There is a slider switch around the headlight **** for the dome lights.
Old Jul 12, 2006 | 01:23 AM
CentralCoaster
Originally Posted by Insane1
Hey CentralCoaster, is that a picture of you and your vette on racelegal.com website with the fastest reaction time?.
Yup! My first perfect, finally after coming so close so many times.
There's probably a half dozen other ones in the archives too.
Old Jul 12, 2006 | 01:31 AM
Insane1's Avatar
Insane1
If I ever get my car running again maybe I will see you down there. Have new Edelbrock aluminum heads and a LPE 74211 roller cam to install.
I saw one in the same set of you taking off. What are your times?
Old Jul 12, 2006 | 01:36 AM
CentralCoaster
Best is a 8.64. I've been running brackets lately and trying to improve my reaction times and consistency. I think I had a .502 and .503 that night also I've got some more parts on the shelf though.
As bob barker might say, "come on down!" Need any help with the topend work?
Old Jul 15, 2006 | 02:56 AM
Insane1's Avatar
Insane1
Just need the time to put everything back together. Still need to get a timing set and some shorter pushrods.
To courtesy lights when wet
