Torque specs for upper control arm on c4 corvette
Old Jul 12, 2006 | 06:44 PM
Jim5pt7v8's Avatar
Jim5pt7v8
Default Torque specs for upper control arm on c4 corvette
I am looking for the torque specs for an ’87 Z52 Corvette for the front upper control arm bushings. I just installed poly bushing in the uppers and I need to know what the torque is for the large nuts on either end of the control arm. Not the alignment bolts but the nuts that press against the bushings. I have heard several different numbers but can’t find a common one.
Also, if anyone has a torque listing for everything on a c4 that would be great. Just ordered the Helm manual so it everything might be in there but haven't seen it yet.
Thanks!
Old Jul 12, 2006 | 07:40 PM
CFI-EFI's Avatar
CFI-EFI
You pretty much have to go by what your are comfortable with or can get from a trusted front end expert. As per Chevrolet, those bushings are not serviceable. In order to replace them, you have to buy new upper control arm assemblies, with the shaft and bushings installed. You can't even buy aftermarket factory replacements like Moog. The only way to replace those bushings is to do as you, I, and many fellow CFers did and replace them with "performance" bushings. Consequently, there is no factory torque spec for those nuts. I had my bushings pressed in for me. When my jumping up and down on the upper ball joint wouldn't swivel the "A" arm down to where the ball stud would reach the knuckle, I figured they were too tight. Best advice I can offer is to go by feel.
RACE ON!!!
Old Jul 12, 2006 | 10:12 PM
Grease Monkey's Avatar
Grease Monkey
From: Hampton, VA Yea, i'm a redneck... but you love it
Cruise-In 8-9 Veteran
aka/Trunk Monkey/Banned For Life/Corvette For Life
i just finished mine, i just did it to feel
Old Jul 12, 2006 | 10:21 PM
Jim5pt7v8's Avatar
Jim5pt7v8
An Eckler's tech told me 96 ft lbs. But another mechanic looked it up as 63ft lbs.? Does either seem right? I'm not good with feel for this particular job. I have never done the suspension before.
Old Jul 16, 2006 | 09:52 PM
Jim5pt7v8's Avatar
Jim5pt7v8
There has got to be a specification for this torque. Will the Helm manual have this?
Old Jul 17, 2006 | 02:59 PM
CFI-EFI's Avatar
CFI-EFI
There does NOT have to be a spec for that torque. It isn't in MY Helms, and the reason is, that since the bushings are (officially) non-serviceable, there is no need to either loosen or tighten that nut.
RACE ON!!!
PS. I'd LOVE to know where the "another mechanic looked it up as 63ft lbs.?"
Old Jul 17, 2006 | 04:22 PM
CentralCoaster's Avatar
CentralCoaster
From: San Diego , CA Double Yellow DirtBags 1985..Z51..6-speed
96 ft-lbs is WAY TOO MUCH FOR ALUMINUM NUTS.
Old Jul 17, 2006 | 06:21 PM
Jim5pt7v8's Avatar
Jim5pt7v8
RACE ON!!!
The other mechanic used Alldata to obtain the value.
They had to be tightened at some point when the car was built so in other words. There has to be a torque spec. It is just a matter of who knows it!!
Old Jul 17, 2006 | 06:45 PM
96GS#007's Avatar
96GS#007
Although I hate to admit this, CFI is right
There's not a spec in my '96 Helms manual and the bushings are not serviceable items in the eyes of Chevrolet. Therefore a Service Manual is not going to have the manufacturing information you're looking for.
Generally you tighten until you can feel the arm binding during rotation and then back the nut off until the arm rotates freely. Although not applicable to poly bushings, Global West specified 10lb/ft (yes, ten) for their aluminum/del-a-lum bushings that I have on my car.
Old Jul 17, 2006 | 06:52 PM
Jim5pt7v8's Avatar
Jim5pt7v8
Now I have conflicting info again as one post says until you can't move the arm but you state until it moves freely. I would think the control arm should be fairly ridgid in its movement. Let's just hope my guess of 50ftlbs is right....
Any more ideas let's hear em!
Old Jul 17, 2006 | 06:57 PM
CFI-EFI's Avatar
CFI-EFI
That is freaking' Auto Zone! The well known universal authority on any and everything C4. That is the same outfit that wants to know if my '84 is a convertible, when I go to buy spark plugs. Or what engine it has. Ohmygoodness! I wonder what their source of information is? Obviously it isn't the factory service manual (FSM), as they would like to have you believe. If all else fails, try some common sense. On second thought, you probably would be better off if you farm it out.
Don't worry. Those aluminum nuts thread onto an aluminum shaft. So it's probably OK.
RACE ON!!!
Old Jul 17, 2006 | 07:25 PM
96GS#007's Avatar
96GS#007
Rubber bushings will not allow rotation of the arms. Poly or other bushings like my Global West bushings will. The other post stated he tightened them until they wouldn't move and then he backed the nut off from there. Btw, the factory uses their equivalent of red Loctite on the threads to keep the nuts from backing off.
Old Jul 17, 2006 | 09:15 PM
Jim5pt7v8's Avatar
Jim5pt7v8
Yeah the rubber works off twist while the poly more like a bearing. And I noticed the red on the threads so I did use the red loctite as well. I think the vibe I'm picking up is it should be able to move, but firmly and smoothly. Keeping that in mind that it looks like I'm in a good spot with the tightness. I'm a numbers guy so it just makes me feel better to go by the book. That isn't always possible so feel it is!
Thanks all!
Last I checked Autozone wasn't a mechanic.
But thanks for the insight.
Old Jul 17, 2006 | 09:22 PM
Corvette Kid's Avatar
Corvette Kid
Large Impressive Member
From: Good health is merely the slowest possible rate at which one can die
St. Jude Donor '04-'05-'06-'07
No sh*t? Where'd you park your squad car, Dick Tracy?
Old Jul 17, 2006 | 09:30 PM
Jim5pt7v8's Avatar
Jim5pt7v8
Only a matter of time before I got hit by the sarcasm. Oh well guess every newbie has to go through it on each forum.
Old Jul 17, 2006 | 10:12 PM
Corvette Kid
That's NOOBIE, noob. It's only because you seemed to so completely miss CFI-EFI's sarcasm. Feel the love! And welcome aboard.
Old Jul 17, 2006 | 10:34 PM
WEH 2000C5's Avatar
WEH 2000C5
You guys are HOT tonight !
To Torque specs for upper control arm on c4 corvette
Old Jul 17, 2006 | 10:45 PM
CentralCoaster
First off, GM doesn't invent the torque specs that are in their manual. SAE or someone else most likely defines these based on thread pitch, bolt size, and material, and GM selects the bolt size that does the clamping they require and the safety factor they want.
Hope this helps:
http://www.engineershandbook.com/Tables/torque3.htm
2024-T4 Aluminum, Dry torque in ft-lbs
1/2"-13.... 313
9/16"-12... 413
5/8"-11.... 715
Not sure what size the control arm bolt is.
Old Jul 17, 2006 | 11:32 PM
86PACER's Avatar
86PACER
Yes, the torque spec for that bolt is not in the manual because GM though of the control arms as a complete unit and not serviceable.
When I did my front bushings, I tightened that nut till the free space between the bushing and bushing washer behind the nut was gone, that would have otherwise created unwanted foward and aft movement, but still not bind the normal travel of the control arm. Basically, till the bushings just began to compress, and where seated flush is when I stopped.
Perhaps contacting the vendor of a front end rebuild kit might know the spec?
Old Jul 17, 2006 | 11:38 PM
Jim5pt7v8's Avatar
Jim5pt7v8
I guess I should have done this....
SARCASM ---> "Last I checked Autozone wasn't a mechanic"<---SARCASM.
Please shoot me if I own a vette and go to Autozone for mechanical advice. That is what this forum is for!!
