schematic for headlight switch?
Old Jul 12, 2006 | 10:59 PM
VinceC5's Avatar
VinceC5
Default schematic for headlight switch?
helping a friend out and need a schematic for the headlight switch. Or if anyone can tell me what the "self resetting" breaker is and if it's supposed to be a closed or open circuit with the headlight switch assembly removed from the car.
The car is a 1996.
thanks in advance
Old Jul 12, 2006 | 11:43 PM
ALLT4's Avatar
ALLT4
96 for ya...
The self resetting circuit breaker is just what it's name says it is. I haven't looked inside mine but typically it's a bi-metal contact, when too much current is drawn it heats up and bends away from the contact. When the excessive current draw is removed it will cool and bend back into contact with whatever it's supposed to make contact with.
With the switch removed from the car you won't have jack to the headlights.
Old Jul 15, 2006 | 12:53 AM
VinceC5's Avatar
VinceC5
Default thanks for the schematic.
Anyone know a part number for this circuit breaker. I would hate to have to replace the switch ($200+) for a $0.20 part.
Old Jul 15, 2006 | 04:30 AM
Motorhead Matt's Avatar
Motorhead Matt
The GM part number I found was 3-H21,4. But, I think you are looking for a general part number. Keep in mind that most car parts are custom molded to "fit" where they need to go.
If you are not sure if it's bad and the price for a new one is too pricey, try a junk yard. Just because the front-end was totaled on a bad car dosen't mean a switch is bad.
I Hope that atleast I got you going in a somewhat right direction...
Old Jul 17, 2006 | 11:11 PM
VinceC5's Avatar
VinceC5
Default thanks all for the information
Old Jul 18, 2006 | 03:15 PM
SunCr's Avatar
SunCr
As far as I know, it's part of the switch - there isn't any servicable part and all of the headlight switches I've seen appear to be epoxied together. The schematic shows that the switch is hot at all times, so there should be power at the switch regardless of whether the breaker is open or closed. Pull on the switch and as long as the breaker is closed, the contacts will direct power to the headlights, motors, etc. If there's a short or overload, the breaker will open and the closed contacts don't get any power. To troubleshoot, simply check the power at the switch first - in and out. If in, but no out, you're going to have to work your way through the downstream stuff to find the short or whatever is sucking the life out of it. If in and out, there's just a bum ground somewhere. Anyway fix what's broken and the switch should work again.
To schematic for headlight switch?
