Reset Service engine soon light
Old Jul 14, 2006 | 05:28 AM
wishmaster23's Avatar
wishmaster23
7th Gear
Default Reset Service engine soon light
Hey Guys,
I have a question and i hope you guys can help me out.
I have read the forum before asking this question but it didn't became all clear to me.
A good friend has bought a corvette form 1988.
Now after a while the light service engine soon went on, this is correct because the oil, brakes and other stuff needed maintains.
Now my father how is a mechanic gave the care the full maintains.
But now he has to reset the light SERVICE ENGINE SOON.
Now my question is:
How does he do this??
I hope you guys can tell me easy how to do this or with what steps do I proceed?????
Thanks you guys….
Hope to hear from you guys soon
Old Jul 14, 2006 | 07:07 AM
PAINTER MAN's Avatar
PAINTER MAN
All you have to do is disconnect the battery.
Old Jul 14, 2006 | 07:23 AM
wishmaster23
7th Gear
fist off al thanks for you reaction
seccond, and then the light will go out? it is reset?
because normaly you do this to rest a ABS or ASR light... never know that is also works for a Service engine soon light...
I am going to try it when i get home.... thanks for you answer i hope it works
Old Jul 14, 2006 | 07:29 AM
runner140*'s Avatar
runner140*
Disconnect the negitive battery terminal, wait 60 seconds and reconnect.
Old Jul 14, 2006 | 08:41 AM
RRT vette's Avatar
RRT vette
You can either disconnect the battery for 30 sec or pull the ECM fuse. Both of these will reset the ECM but if the code hasn't been fixed the Service Engine Soon will appear again in the first minute of engine run time.
http://www.yjshadow.com/ALDL_codes.htm
Follow the first part of the instructions and not the codes, they differ with a vette.
Old Jul 14, 2006 | 12:46 PM
wishmaster23
7th Gear
Hey Guys,
First of all thanks for all your reactions...
I have disconnect the battery, but the problem isn't gone...
The car just needed new brakes and new oil and stuff like that...
In the latest message I was refereed to a website.... but this al very strange to me
Can somebody help this n00b a little.
What is step 1 until… what I have to do to rest the light service engine soon….
Hope somebody will help me out.. I am lost and so is my father…
Old Jul 14, 2006 | 12:55 PM
RRT vette's Avatar
RRT vette
This is what you need to do. The SES light will go off when the battery is disconnected, but the light will show back up if the code is not taken care of. I posted a website that tells you how to pull the code(s). Read the flashes and report back.
Old Jul 14, 2006 | 01:01 PM
RRT vette's Avatar
RRT vette
The SES light will not come on because the car needs new brakes or new oil. It is normal for the SES light to come on while the key is in the on position, but not if your driving the car. When a code is set in the ECM, this means that the ECM has seen a voltage/signal out of it's range and makes the SES light come on. You will need a paperclip in the shape of a U and insert it in the two top right terminal (A and B) of the ALDL. Turn the key to on and the SES will start flashing codes....code 12 is normal and is just a diagnostic check. The fan will run along with various sensors.
Old Jul 14, 2006 | 02:24 PM
wishmaster23
7th Gear
Thanks for your help so far
I followed your instructions and the light flashes three times a code 34. On this site http://www.corvettedoctor.com/1985_91_DTC_Codes.html it gives the following discripion Mass Air Flow Sensor Low. Is this a correct? Is so what should I do? I have disconnected the battery but after starting the engine again the light came on again, so it doesn't reset.
I hope you can help me with this problem
Old Jul 14, 2006 | 02:36 PM
kalister1's Avatar
kalister1
When you disconnect the battery you reset the SES light, then you started the car again and it still see's the same fault so it turns the light back on. I have read that MAFS can be cleaned, but I have never done this.
Old Jul 14, 2006 | 03:40 PM
vinnies87's Avatar
vinnies87
St. Jude '03-'04-'05-'06-'07
Until you fix the problem (34) the SES light will continue to come on with the start of the car, and will return as soon as another error code is detected.
Old Jul 14, 2006 | 04:40 PM
wishmaster23
7th Gear
i understand that, that i have to fix the problem.
But what i wanna know is how do i fix it. The light flashes three times a code 34. And when i look at the this web site:
So what i wanna know is this a correct? and is so what should I do?
I cleaned the MAFS but it still didn't work.
I wanna know if code 34 is really the MAFS and not something else
and how i can fix this
please anybody????
Old Jul 14, 2006 | 06:15 PM
RRT vette's Avatar
RRT vette
You are correct if indeed it is a code 34. The light will blink three times in a row...pause...blink four times in a row. You should have gotten a code 12 before and after the code 34. Here is what to do : check for loose or damaged air duct. Disconnect the battery and clear the codes. Reconnect and (do not ground the ALDL), and start the engine and run above 2000 rpm for 1 minute or until the light comes back on. Now turn the engine off and turn the key to on and ground the terminal.
If the code is still there, disconnect the battery again and clear the code. ALDL not grounded, disconnect the MAF sensor and start the engine and run above 2000 rpm for one minute or until the light comes back on. Now turn the engine off and turn the key to on and ground the terminal.
If the code 34 is still there check for short to ground in the dark green wire at the MAF. Have the connector off and use a voltmeter and test the dark green wire with the key on. It should show 5v when tested and if it doesn't, check the dark green wire at the ECM. The ECM could be faulty if there is not 5v there.
If a code 33 shows up after doing this. The MAF is bad and needs to be replaced.
This comes directly from my 86 FSM. Maybe this will get you in the right direction. My guess is that it is a loose connection or a shorted wire.
Old Jul 15, 2006 | 03:56 PM
wishmaster23
7th Gear
Really thanks a lot for you answer…
It means a lot to me that you give me a complete answer like that…
Tomorrow father and I are going to try this…
And again thanks I will keep you informed…..
Greetings From The Netherlands….
Old Jul 18, 2006 | 06:48 AM
wishmaster23
7th Gear
The MAF was bad and needed to be replaced, i orderd a new one.
This week i will get it and put it into the corvette i hope the problem is gone than...
Thanks for all your help.. and i will keep you posted
Old Feb 15, 2025 | 03:06 PM
altownsend's Avatar
altownsend
Default Service Engine Soon Light
I tried this fix, and the Service Engine Soon light came on again.
I had H32, so I changed out the 02 Sensor and the Knock sensor. The Service Engine Soon light was on. I disconnected the negative side of the battery, waiting about 30 minutes working on other projects, re-connected the battery and started the engine. Service Engine Soon light came on immediately.
Old Feb 15, 2025 | 05:11 PM
Tunedport90's Avatar
Tunedport90
kinda a old post, if your blinking a code 32 it’s a egr solenoid failure or temp switch if applicable.
To Reset Service engine soon light
Old Feb 15, 2025 | 06:47 PM
altownsend's Avatar
altownsend
Default Codes
Thank you for your input. After reading your post, I went back out to check the codes again.
I received two codes, see below
1.
H41
4.
H43
I will look these up and see what system they relate to. If you know, feel free to share the fix with me - thanks
Old Feb 16, 2025 | 10:16 AM
Tunedport90
https://www.corvetteforum.com/forums...-code-h41.html
iirc H43 is a knock sensor code
Old Feb 16, 2025 | 09:04 PM
altownsend's Avatar
altownsend
Thanks for the response. I changed out the Knock Sensor and the 02 Sensors. I still get the Service Engine Soon light. I noticed that my oil pressure gauge bottomed out to the right also. I am researching this and it seems as though it is the Oil Pressure Sensor. But, mine has three prongs instead of one.
